4x4 van conversion
Old Feb 14, 2003 | 12:44 PM
pfogle's Avatar
pfogle
4x4 van conversion
Think of converting a 92 1/2 ton van to 4x4, want the 3/4 ton axles tho.... anyone know of any problems I may encounter? I already know I have to find a s/c truck so the driveshafts fit.
Old Feb 14, 2003 | 06:27 PM
Diesel_Dummy _'s Avatar
Diesel_Dummy _
4x4 van conversion
you will run into more problems then its worth. there is a company called Quigley in pensilvania that converts full size vans to 4x4 , but they will only do it to new vans and for 6 grand on top of the price of the van.
good luck
Old Feb 14, 2003 | 06:46 PM
pfogle's Avatar
pfogle
4x4 van conversion
If I could afford a Quigley I would buy one... but 50 grand is out of my reach. The wheelbase between the van and the s/c long bed are the same, the chassis are almost identicle.
Old Feb 14, 2003 | 08:26 PM
Diesel_Dummy _
4x4 van conversion
almost but not the same up front , i think you'd be better off doing a solid axle swap then trying to get a TTB under there.
Old Feb 14, 2003 | 08:46 PM
pfogle's Avatar
pfogle
4x4 van conversion
It'll be converted to an off-road vehicle for pulling my idiot little bro and his idiot friends out of the mud when their chevys get stuck........
Old Feb 15, 2003 | 04:42 PM
Diesel_Dummy _
4x4 van conversion
have you ever looked at a Quigley van ?
the front drive shaft is on the right side of the truck and the front diff it on the right side also , oppisite from a normal TTB ford setup.
you will need a transfer case and a trans tail adaptor to get the shaft on right side of the van. i wonder if Quigley has a web site ?
Old Feb 15, 2003 | 04:47 PM
Diesel_Dummy _
4x4 van conversion
http://www.4x4fords.com/conversion3.htm
http://www.quigley4x4.com/AboutQM/Whoarewe/WhoAreWe.htm
http://www.glinx.com/~sbest/
check it
Old Feb 16, 2003 | 06:56 AM
pfogle's Avatar
pfogle
4x4 van conversion
Ummmm D.D. you need to take a closer look at the websites that you sent me...... ALL of the vans listed have the front dif on the LEFT side.
Old Feb 16, 2003 | 10:52 AM
92f150I6's Avatar
92f150I6
4x4 van conversion
The twin I beam sewt up on the van looks alot like the one on my F150. Are they not the same?
Old Feb 16, 2003 | 11:49 AM
pfogle's Avatar
pfogle
4x4 van conversion
I have owned both trucks and vans and I have not noticed any diff....
Old Feb 16, 2003 | 12:53 PM
Diesel_Dummy _
4x4 van conversion
all but the quigley vans.
i found those sites in less then 2 mins of searching
Old Feb 16, 2003 | 01:03 PM
Diesel_Dummy _
4x4 van conversion
http://www.4x4fords.com/images/qvan2.jpg
to me it looks like the front diff is on the passenger side of the van
Old Feb 16, 2003 | 01:14 PM
pfogle's Avatar
pfogle
4x4 van conversion
It appears that way on the quigleys.. not sure of their reasoning.... the motor in the van is already offset to the right so the left side axle is a sure fit. and the motor is out of the way of the driveshaft. Look at
Old Feb 16, 2003 | 01:24 PM
Alan P's Avatar
Alan P
4x4 van conversion
http://www.pathfinder-vans.com/DIY_C...Ford/ford.html
http://www.clydesdale.bc.ca/
http://www.quadvan.com/
a few more 4wd van conversion links..some awesome rigs.
Alan P
Skip1970
Oct 27, 2013 04:02 PM
LarryP2
20
Aug 14, 2012 09:28 AM
Dr.B
Jan 30, 2010 02:32 PM
Tater50
Nov 22, 2006 01:19 AM
brychar
Jan 21, 2001 10:24 AM
