Thanks Mark Just did my F250 Van used a 30 Ton press took 6000 lbs to get one side free sure didn't come apart like that. Should have used a little heat.
I did mine recently as well. There's a huge thread in the super duty section with lots of info, those videos are there along with some others. The tool you can rent from Advanced that has the larger super duty cups and stuff worked like a champ, just make sure you have as many threads engaged as possible before you put the gun to it or bad things happen.
How do you know if your ball joints need replacing? i.e what kind of symptoms do you notice? I have about 83K on my 6.0 and alot of people seem to be having problems near that mileage.
Also, after watching the video it's probably beyond my mechanical ability (although my son is studying to be an open wheel mechanic in the Army) what would a job like this cost at a shop?
guessing at labor cause im not a frontend tech. labor would start about 6.0 hours and go up from there depending on other needs.
to check ball joints requires that you lift the truck from the frame so the wheel is off the ground, then while prying up on the tire (with a pry bar) you would look for and measure for excessive play up and down.
symptoms could be poor returnabaility, excessive play. poping sounds from front end, abnormal tire wear. to name a few.
The best thing to do is to jack up the truck and pry up on the wheel. I saw no signs of worn ball joints, until I failed my state inspection. They were pretty worn when I got in there to replace them. The first video shows how to do this test, just like Cheezit said. It's pretty easy.
The dealer wanted just under 1000 dollars per side. The parts were 150-250 depending on whether or not you do the seals, and the tool can be rented for free (~170 dollars, which gets refunded, at Advance Auto). It is a fair bit of work though. Most people report taking a good 8-10 hr day the first time. I had about 5 hrs into one side thanks to breaking the tool, and some other issues. I could probably do it again in ~3 hrs. I'm fairly well equiped for an amatuer mechanic though. If you can cut, grind, and torch your way through the inevitible obstacles you'll encounter, you'll have less trouble. I hate this kind of work personally, but I'm glad I went through it and learned some of the tricks, it will pay off as time goes on.
takes me about 4 hours in the shop with the hand press. the front end guys laugh at me. they can do 2 to my one.
LMAO, that's funny. But ****, if they're doing it in 2 hrs my 3 hr estimate might be a little too optimistic. I respect the guys that do this work day in and day out, but they can have it. Same with fabricators. I spent months doing all of the piping and stuff for my compound turbo setup, when a fab/welder guy could have done it in 40 shop hours or less. For me, it's just too much like work.
My left side ball joints have gone out and I'm going to attempt to do them, I've done ball joints on a humvee while i was deployed to iraq so I got some experiance I guess haha.. I know I will need to get a new inner hub seal, thrush washer, and the yellow hub o ring, and axle dust ring, is there anything else?
Duck when the shooting starts. Thanks for your service.
