Leaking HPOP, 2003 F250 7.3l
I too, have a leak coming from the HPOP. It's not coming from either line but rather from the "non-removable" plug on the lower driver's side part. I called and checked with Ford and that is a "You are fcuked part" $1000 for a new HPOP. There has to be a way to fix this as my finances are tight, due to truck issues last year with blown injector seals, ICP sensor, Wiring harness under the valve cover and of course, tires.
This is my only vehicle and I cannot have it down. So this weekend I need to get it repaired until I can get enough to buy a "reman" pump.
Can anybody help me with some directions on how to remove said HPOP and such? Thanks ever so much.
To add to what Greg posted Bob sells a repair kit as well. There is a pdf on this link: Replacement O-rings for Ford Diesel Engines
Well that you are ****ed part happens to cost around $30 plus shipping. Click the link for where to buy it. That page also has instructions on how to perform the repair. Replacement O-rings for Ford Diesel Engines
The link Greg provided basically covers the same thing.
PJ, welcome to FTE! You might know me better as RMKcowboy from BCR You can definitely fix that "non serviceable" plug pretty easily. What you should do though is send that pump and $100 to Joey at Terminator Engineering and have him modify it for you. After you repair the "Non serviceable" plug of course
Already have o-rings but it's not the HPOP lines that are leaking. Clean as a whistle. The leak is coming from the bottom side by the "non-removeable" plug. I can see where it comes out, hits the manifold and runs into the "valley" thence dripping down the rear of the motor and onto my floor.
I've gotta get this fixed this weekend before I end up buying another $30 gallon of oil. Just to have it drip into my driveway.
Superduty4x4, what is being modified for $100? I've looked at the site and never seen this advertised. I would consider it myself if it is say a rebuild for $100. I know that he does some work on 15* pumps to modify them vs purchasing a 17*. But i would be interested in finding out what the modification covers.
PJ, take a 12 pack out to the garage and have a heart to heart with the truck. And threaten to kick her in the junk if she doesn't start behaving properly, that usually solves the problems for me
Thanks, I wasn't asking to determine if it was something I could do, I was just wondering if with my kind of miles this would be valuable or even how to go about getting it done by him. This seems extremely reasonable, but I dont know if I should just consider a new pump or have my current one "modified". If this was essentially a rebuild of sorts, I would love that price too.
Joey knows pumps. Shoot him an email and tell him what you're thinking. If he gets your pump and thinks you'd be better off with a new one I'm sure he'll tell you. Terminator Engineering
Joey won't disclose what he does to the pumps but he has many of them out there and there are very, very few complaints. He doesn't advertise them because he gets enough business from guys like me telling everyone about it that he spends most of his time modifying 17° pumps
I'm in love with my 03, just tired of the little chit.
Where is this Joey Fellow located? Very interested but cannot have any down time as I don't have another vehicle and I drive 140 miles a day to work.
I think Im having the same problem, but I cant find where the oil is coming from how do I make sure this is what is leaking? with the truck parked on incline the oil is running down the back of the motor when it on flat ground the valley fills with oil...Help please..
Once you identify which spot is leaking, it should be a simple fix.
