can't find replacement dipstick
Old Aug 5, 2010 | 05:30 PM
f250mansc's Avatar
f250mansc
I've been working with my son on our 1977 f100. When putting a set of headers on, we broke the dipstick. I found a part number on the stick
E9ue6750ca. It is a 30" long dipstick and have been all over. If anyone
might know how to find something like this, we would sure appreciate the
help.
Old Aug 5, 2010 | 05:33 PM
Fordman18's Avatar
Fordman18
What size engine is it?
Old Aug 5, 2010 | 05:52 PM
f250mansc's Avatar
f250mansc
Sorry, I forgot to say a 302. Don't think it is the original
motor
Old Aug 5, 2010 | 06:22 PM
jim collins's Avatar
jim collins
Is it going in to the side oil pan or in front of the engine? If in front you can buy a chrome tube and dipstick for a early 289, thats what I did on a 84 302 , It show's the correct amount of oil.
Old Aug 5, 2010 | 07:23 PM
f250mansc's Avatar
f250mansc
It is on the right side and goes
directly thru the block into
the oil pan. I'll try your suggestion. Thx
Old Aug 8, 2010 | 10:35 PM
kjvforme's Avatar
kjvforme
help.
Go to the 61-66 ford truck section and PM the "Numberdummy" give him the part number he should be able to do a part number search for you and tell you where you can get an original.
Old Aug 8, 2010 | 10:44 PM
steponit's Avatar
steponit
Part Number is E9TZ-6750-B
89 E series 302
Green Sales has one
Old Aug 8, 2010 | 11:29 PM
kjvforme's Avatar
kjvforme
See there you go, what once was lost is now found.
Old Aug 9, 2010 | 07:25 AM
f250mansc's Avatar
f250mansc
I really appreciate the help, I guess I
now know the year of the engine.
Old Aug 9, 2010 | 12:32 PM
steponit's Avatar
steponit
That part number is not a determination of the year of the engine.
You need to check the casting numbers of cast iron engine parts to determine that.
Old Aug 9, 2010 | 12:44 PM
f250mansc's Avatar
f250mansc
Ill look on the engine to verify that motor.
Called Green Sales, said the dipstick with that number
was for a Econoline 350 van with a 302. I'll find the engine
number to make sure. Thanks again for the support
Old Aug 9, 2010 | 12:59 PM
fmc400's Avatar
fmc400
MSEE
You can get a universal dipstick from most parts stores and I'd assume you'd be able to cut it to length if needed, and use the original dip stick as a reference to scratch the fill level on the new one. They're in the "Help!" section with the miscellaneous clips, fittings, etc.
corralch
13
Oct 15, 2015 04:49 PM
460 FORD MAN
27
Jan 28, 2015 11:47 AM
retroluxe
16
Jan 23, 2007 05:45 AM
Spktyr
Texas Chapter
May 27, 2004 05:55 PM
