So, I think it is finally done snowing for the year and the plow is off. Anyone have any clever means of adding weight to the front end to help soften the ride a little? It was a more smooth ride with the plow on.
Do you have a front receiver hitch?
Do you have room to put front receiver hitch on with plow bracket under there?
Light bar?
Different bumper?
Add lead weights to inside of bumper?
Add a winch?
Light bar?
Different bumper?
Add a winch?
I like the, 'weights inside the bumper idea'. I will do some investigating!
The more weight you add, the more your fuel mileage will suffer and faster the suspension parts will wear out. Reconsider dropping tire pressure and calling it a day.
