Sponsored by: Real Truck
2011 F250 - Adding Front End Weight
Old May 4, 2011 | 12:29 PM
SturgeonHunter's Avatar
SturgeonHunter
So, I think it is finally done snowing for the year and the plow is off. Anyone have any clever means of adding weight to the front end to help soften the ride a little? It was a more smooth ride with the plow on.
Old May 4, 2011 | 12:45 PM
senix's Avatar
senix
Just lower the air pressure a bit. Don't go too low as your TPMS will come on.
Old May 4, 2011 | 01:06 PM
SturgeonHunter
Thanks. I have done that and it does help but I am still curious about adding weight and leaving tire pressure set for heavy load.
Old May 4, 2011 | 01:38 PM
senix's Avatar
senix
I really don't have any ideas except maybe leave some of the snow plow attachments on there.
jlalanas's Avatar
jlalanas
I run about 55lbs and 65 lbs front and rear. Once the tires heat up a bit, they're 60 and 70 and the TPMS has not come on.
Old May 4, 2011 | 07:12 PM
Wagion's Avatar
Wagion
Do you have a front receiver hitch?
Do you have room to put front receiver hitch on with plow bracket under there?
Light bar?
Different bumper?
Add lead weights to inside of bumper?
Add a winch?
Old May 5, 2011 | 05:24 AM
SturgeonHunter
Light bar?
Different bumper?
Add a winch?
I like the, 'weights inside the bumper idea'. I will do some investigating!
Thank you!
Old May 5, 2011 | 05:31 AM
rattleNsmoke's Avatar
rattleNsmoke
The more weight you add, the more your fuel mileage will suffer and faster the suspension parts will wear out. Reconsider dropping tire pressure and calling it a day.
TFLT
Dec 29, 2015 07:41 PM
ontariofarmer
Jan 5, 2015 07:04 PM
bigern26
Sep 8, 2010 10:37 PM
burgf250
Dec 27, 2007 10:49 AM
8 Lugs
Nov 25, 2005 09:15 AM
