trans fluid change
Old Aug 5, 2010 | 07:19 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by mikewrt
In the torque converter or on the plumbing that goes to the spin on filter/cooler? I guess I don't understand fluid flow path.
Neither. It is inside the transmission in the pump body. That's right behind the torque converter.
Old Aug 5, 2010 | 07:34 PM
Zmann's Avatar
Zmann
I wish it was easy to turn it off for the backyard flusholigist like me lol
Old Aug 5, 2010 | 08:17 PM
69cj's Avatar
69cj
Take it to the dealer, get a hot flush, have a beer and let the brain cells equalize.
Old Aug 5, 2010 | 08:25 PM
Zmann's Avatar
Zmann
I was half way thru mine when I realized I was screwed ,, there were a lot of bad threads out there obout flushing these .. older ones did not have the temp control ,, I have done my pan and internal filter and remote 3 times and 3 pan drops .. I would have been way better with a dealer flush .. but back then the word flush sounded like a shortcut ,, they should call it a hot fluid exchange or something ??
but I am having a beer now !!
Old Aug 5, 2010 | 08:53 PM
mikewrt's Avatar
mikewrt
Mark, Thanks for sharing your smarts . . . would you mind drawing out a general schematic of the fluid path for the 5R110.
Fluid goes from: Pan => Internal Screen => Pump => Thermostat => ????
Did the 5R110 have the thermostat from the beginning? Is it possible that my 03 doesn't because it was introduced in a later model year?
Old Aug 5, 2010 | 09:07 PM
bismic's Avatar
bismic
I know you were asking the other Mark, but here is some reference material -
<TABLE style="WIDTH: 692pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=923 x:str><COLGROUP><COL style="WIDTH: 692pt; mso-width-source: userset; mso-width-alt: 32608" width=923><TBODY><TR style="HEIGHT: 12.9pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 692pt; HEIGHT: 12.9pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=17 width=923></TD></TR><TR style="HEIGHT: 25.85pt" height=34><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 692pt; HEIGHT: 25.85pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=34 width=923 align=left>http://www.cutawaycreations.com/cutaways.php?project=ford-torqshift-transmission-cutaway#/IMAGES/ford-torqshift-transmission-cutaway/images/image5.jpg</TD></TR><TR style="HEIGHT: 12.9pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 692pt; HEIGHT: 12.9pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17 width=923 align=left>http://atsg.com//dyndata/articles/pdf/Ford%205R110W%20Torqshift.pdf</TD></TR><TR style="HEIGHT: 12.9pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 692pt; HEIGHT: 12.9pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17 width=923 align=left>http://www.powertraincontrolsolutions.com/download/db/TCM4119SCH.pdf</TD></TR></TBODY></TABLE>
On the video, you can probably start at about 12 minutes:
mms://multimedia.ford.com/seopts/Tech14_250k.wmv
(paste the URL in your browser window)
http://genemohr.com/PowerStrokeDiesel/disassembly.pdf
http://genemohr.com/PowerStrokeDiesel/assembly.pdf
http://genemohr.com/PowerStrokeDiesel/tsb03-18-01.pdf
Old Aug 6, 2010 | 02:13 AM
Mark Kovalsky
Every TorqShift ever built had an internal thermostat.
The fluid path goes from the pan through the internal filter to the pump. The pump sends fluid to several places. One of those is the torque converter. The flow OUT of the torque converter goes to the thermostat. If the thermostat is closed 10% of the flow goes to the cooler line and 90% bypasses the cooler and goes to lube the rear half of the trans, then is dumped to the pan.
If the thermostat is open 100% of the torque converter output goes to the coolers, then to rear lube, then to the pan.
Old Aug 6, 2010 | 08:20 AM
mikewrt's Avatar
mikewrt
Reps to all . . . Very handy. I like knowing how stuff works.
labman1014
Jun 7, 2012 02:12 PM
Headviking
Aug 11, 2010 12:12 AM
vze2sgxa
May 29, 2009 02:15 PM
BrianA
Dec 19, 2007 05:47 PM
amm888
26
Dec 31, 2006 09:57 PM
