trans fluid change
Old Aug 4, 2010 | 09:08 PM
Headviking's Avatar
Headviking
trans fluid change
I was thinking draining and filling back up driving about 1/2 hour, draining 2nd time filling backup, driving 1/2 hour, then draining and dropping pan replacing screen, clean magnet and reinstalling pan and fill. How does that sound Oh and replacing filter toilet filter at the end as well.
does that sound like I would change most of the old fluid?
Old Aug 4, 2010 | 09:17 PM
sammy77's Avatar
sammy77
I do mine every year (about 10k miles). Drain pan, replace both screen and filter and replinish with 7-9qts. If you're goin to go thru all that trouble in 1 day might be worth it for you to just let dealership do it.
Old Aug 4, 2010 | 10:27 PM
Zmann's Avatar
Zmann
the filter in the pan is just a screen and easy to clean ,, I did what you are thinking but only after I was in the middle of a home flush and found out the tranny shortcycles the cooler when cold so I was screwed and couldn't do the normal drain and fill flush
reconsider your dealers hot flush ,, and quiz them as to what fluid they will use
Old Aug 4, 2010 | 10:50 PM
m-chan68's Avatar
m-chan68
I see someone has done some reading. This is actually called the cooler bypass. Part of the PCM's strategy for cold engine operation is to disable TCC until the transmission gets up to operating temperature.
Mercon SP for older Torqshifts. Mercon LV for newer Torqshifts.
Old Aug 4, 2010 | 11:02 PM
Zmann's Avatar
Zmann
sp is no longer made lv is the new sp otherwise valvoline swears they have a compatible fluid
Old Aug 4, 2010 | 11:03 PM
Zmann's Avatar
Zmann
then again I see who I am posting too lol you already know all of this
lol sry
Old Aug 5, 2010 | 01:57 AM
bismic's Avatar
bismic
Pesonally I think this is an acceptable strategy. You do not have to replace the internal screen (unless it is damaged, and then if it is - you probably have bigger issues).
You can replace about 85% of your old fluid this way. I would probably do 3 fluid drains and then a fourth drain and drop the pan. Four changes will get about 90% of the fluid. The key is getting it up to temperature and get full circulation between changes.
Old Aug 5, 2010 | 07:00 AM
bigred66's Avatar
bigred66
So it sounds like just draining the fluid and replacing it once will not cut it. I was not aware of this and glad i read the thread since I'm changing mine next week. So how many quarts of tranny fluid should I buy if I'm doing mult drain/refills?
Old Aug 5, 2010 | 07:09 AM
bismic's Avatar
bismic
You should ge 7-8 quarts out from a drain at the drain plug. Dropping the pan will require 8-9 quarts re-fill.
I would measure the amount you get out.
Drain it 4 times and you need somewhere around 33 quarts.
Be aware that Ford says dropping the pan once every 30k miles is an acceptable alternative to flushing. I just don't like the thought of so much old fluid left in.
Old Aug 5, 2010 | 07:49 AM
mikewrt's Avatar
mikewrt
Where is the trans thermostat? Is it internal to the trans case or is it mounted on the outside? Does any one have a drawing that shows fluid flow through this thing?
Old Aug 5, 2010 | 07:51 AM
bismic's Avatar
bismic
It is internal
Old Aug 5, 2010 | 07:53 AM
mikewrt's Avatar
mikewrt
In the torque converter or on the plumbing that goes to the spin on filter/cooler? I guess I don't understand fluid flow path.
Old Aug 5, 2010 | 09:28 AM
w_huisman's Avatar
w_huisman
I was just in to visit the dealer for a hot tranny flush last week. They did the whole service for $125 total ($119.99 + tax). It's usually $149.99 but I had a $30 coupon that expired on July 31.
Draining and refilling 9 qts x 4 times x $5/qt = $180.
Seems to me you're better off letting them do it, even at regular price for the service.
Old Aug 5, 2010 | 09:37 AM
69cj's Avatar
69cj
I had the dealer do mine w/ hot flush. Didn't notice till I got home that on the receipt there was also 1 qt. of tranny conditioner what ever that is? I did notice a difference in the tranny performance afterwards however. For the good.
Old Aug 5, 2010 | 09:46 AM
w_huisman's Avatar
w_huisman
Originally Posted by 69cj
....I did notice a difference in the tranny performance afterwards however. For the good.
Funny you should say that. I thought the same thing but figured it was just my imagination.
