Need Help ????
Old Aug 4, 2010 | 08:24 PM
shady1981's Avatar
shady1981
Post Need Help ????
Let me just say thanks in advance, I am new to this, so sorry for any screwups in advance.
My Truck:
I have a 1978 F150 4x4 with a 6.6L I just bought this about a month ago just to hunt out of and drive around the country. When I bought the truck it had been sitting for a bout a year and had been a farm truck most its life with only 108,000 miles on it.
What I have done:
I have cleaned tank and reinstalled with new sending unit and fuel filler lines, new fuel pump, rebuilt carb, new siloniod, new starter, new plugs, and new plug wires.
My Problem:
Truck was running great drive it for about 5 strait hours with no problem, then all of a sudden started cutting out (like it was running out of gas), truck cut off, started it back up and drove 1/4 mile and started doing the same thing.
Due to the fact gas guage is not working I thought it was out of gas, about two hours later put 10 gal of gas in it, truck started up and drove it about 2-3 miles and started cutting out again, then cut off. I could start it back up and drive 1/2 mile and it would start again, as soon as it cut off it would start back up and go another 1/2 mile and on and on till I got it home about six miles away.
The following day started up great and left it running in park for about an hour, soon as i put in gear it cut up like in had no gas, put in park it ran great.
Not shure what is wrong, any advise?
Old Aug 4, 2010 | 09:06 PM
Fordman18's Avatar
Fordman18
I had a similar problem for a while. Changed the coil and ignition module, that didn't seem to help. Then I changed the distributor ( had to use a hammer to get it loose enough to rotate and pull it out) and installed a Holley red label electric fuel pump at the same time. Not sure which of those two fixed it.
Old Aug 4, 2010 | 10:23 PM
vtjvt's Avatar
vtjvt
It could be fuel or electrical causing the problem. Hook up a pressure gauge in the fuel line by the carb and when it starts cutting out check the pressure. At least that will tell you what direction to start going.
Old Aug 5, 2010 | 07:39 AM
radar457's Avatar
radar457
that sounds like classic ignition module failure to me. I would first replace that and see if it fixes it..bet it does...
Old Aug 5, 2010 | 08:00 AM
mikeo0o0o0's Avatar
mikeo0o0o0
You said you replaced the fuel filler hoses and replaced the sending unit. Doing that I assume you replace the flexible hose from the tank to the hard line, same thing for the fuel pump. If your truck is a long bed there is another flexible line mid-way between the tank and fuel pump. If the other suggestions above don't fix it check the condition of this line. If its hard and cracked it could be sucking air instead of fuel.
Old Aug 5, 2010 | 09:27 AM
RedLesPaul's Avatar
RedLesPaul
Start with KISS...Keep It Simple Stupid....
I had this same problem about 25 years ago. Turned out to be a clogged fuel filter. I thought I had bad gas maybe (well the truck, not me) and there was only a 1/4 tank. Seemed to run fine just sitting, so I let it run, and run, and run.....You'd be amazed how little gas gets used idling in park. Anyway, finally put new gas in and it ran rough and died out every couple of miles. Took the fuel filer out, and tried to blow through it, nothing flowing. Maybe $2.50 later, truck ran fine.
Old Aug 5, 2010 | 04:18 PM
shady1981's Avatar
shady1981
Thumbs up Thanks for all the help
I have a new Ignition module just have not replaced it, I will put on this weekend, also have a new fuel filter to install. Will let you know how it goes.
mikeo0o0o0 yes I did replace the flexi lines at the same time I did the tank
Hope this works, then maybe I can get some advise on a few other problems, but one thing at a time.
Thanks again to you all
Old Aug 5, 2010 | 04:57 PM
NorthwestX360's Avatar
NorthwestX360
FYI everyone, always put a little anti-seize compound on your distributor to keep this from happening.
Old Aug 5, 2010 | 05:24 PM
Fordman18's Avatar
Fordman18
That's a great idea. Original owner never touched the timing. Luckily it ran just well enough to get home.
2012F250SUPERDUTY4X4
6.7L Power Stroke Diesel
176
Dec 7, 2018 05:46 PM
BigSix1
Aug 23, 2014 11:14 AM
RANGER589
Electrical Systems/Wiring
Jun 25, 2014 09:09 AM
MI79250
19
Dec 31, 2011 12:18 PM
Julies Cool F1
16
Jun 19, 2010 03:42 AM
