Sponsored by: Real Truck
Brake pads
Old Aug 4, 2010 | 04:44 PM
sammy77's Avatar
sammy77
Brake pads
Just curious to know what type of brake pads most guys are using on their trucks today? I have always used Motorcraft, but I'm getting a little tired of all the brake dust and not to mention they're pulsating again. I was considering ceramic, but don't know how well they stop a truck??(especially when towing or hauling) Thanks for your help
Old Aug 4, 2010 | 04:49 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Hawk LTS and Super Duty pads are popular on here. I have a set that I haven't used yet, because the Duralast Golds from Autozone have lasted a lot longer than I though they would. Duralasts arent bad for $40 a pair, but Hawk has a better reputation here
Old Aug 4, 2010 | 04:52 PM
sammy77's Avatar
sammy77
Any excessive dust?? How do they stop when towing or hauling compared to your stock brakes?
Old Aug 4, 2010 | 05:02 PM
texastech_diesel
Token Redneck
The Duralasts are basically identical to the stock pads are far as sensation, they might fade just a little less. Are far as dust, after towing a 6k trailer to Dallas and back they were barely noticeably dirty, and cleaned up with just a dry rag.
Old Aug 4, 2010 | 05:22 PM
sammy77's Avatar
sammy77
Thanks much
Old Aug 4, 2010 | 06:29 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
I started using carbon metallic from Performance Friction Brakes, no fad and no noise even when pulling heavy loads in the mountains.
Denny
Old Aug 4, 2010 | 09:22 PM
bucci's Avatar
bucci
I use hawk LTS pads and so far won't use anything else on a truck. I used duralast gold before and they don't take the heat while towing and I experienced alot of brake fade and dust. I have duralast gold on my Pontiac Bonneville and the brake dust is extreme.
I have never experienced brake fade with hawk lts pads; brake dust does exist but it is less than what standard or stock pads produce.
Old Aug 4, 2010 | 09:45 PM
sammy77's Avatar
sammy77
Where are you guys getting them from??
Old Aug 5, 2010 | 07:38 AM
GUNNERDOG's Avatar
GUNNERDOG
The pulsating is caused by warped rotors, not pads. Some (including myself) have had good luck with powerslot cryo rotors up front. I paired them with the hawk LTS pads, and couldn't be happier. Not too much dust, but stops on a dime.
Old Aug 5, 2010 | 08:28 AM
Mick83's Avatar
Mick83
Hawk LTS vs Hawk Superduty
What's the difference / which are better?
Old Aug 5, 2010 | 12:11 PM
FORDTUF1's Avatar
FORDTUF1
After reading a lot about this I went with Power SLot Cryos and Hawk HD. I was severely disappointed in the braking performance and the feel, I swear I could feel when every slot hit the edge of the brake pad. When I did the brake job I also went with new calipers too since I had 140K miles on it.
I'm very thorough doing the work too, but I thought okay maybe I didn't bleed enough air out so I did it again, still the same. I'm glad I sold it so I don't have to worry with them.
When my new truck needs brakes I'll stick with standard rotors and try just the Hawk pads only. BTW, I got mine through AUTOANYTHING, their a sponsor (or were) here on FTE.
Old Aug 5, 2010 | 04:02 PM
sammy77's Avatar
sammy77
Yes I definetley know I'm gonna need rotors, again. I was lookin for some help on the pads. Looks like its gonna be Hawk. Thanks
