Transmission Swap????????
Old Aug 4, 2010 | 04:32 PM
HuntM's Avatar
HuntM
I was wondering how much it would cost to do a transmission swap in a 1993 ford f-150 flareside, it has a manual and want to change to automatic. it is a 4x4. How much would the total cost most likely be for the swap?
Old Aug 4, 2010 | 10:02 PM
85e150's Avatar
85e150
You could spend $3 or 4 thousand doing it, if you had it done. New OD trans is $2500, give or take, plus all the labor.
FWIW, I would sell it and buy one with an automatic.
Old Aug 4, 2010 | 10:35 PM
HuntM's Avatar
HuntM
thanks i was wondering about how much it would cost because i was looking at one that was for sale that was a manual. but now that i know how much the tranny would cost me im not interested any more. thanks for the help.
Old Aug 5, 2010 | 12:37 AM
85e150's Avatar
85e150
If you are buying the truck, buy what you want.
BTW, you could also do it for $3-4 hundred, but you'd still have a clutch pedal hanging and you'd shift it via an adapted floor shifter. Sound good? Oh yea, and you might have to swap in a couple of those $125 trannies to get a good one.....
Like I said, buy what you want, there is no shortage of used trucks.
Old Aug 6, 2010 | 04:25 PM
HuntM's Avatar
HuntM
How would it work if I did it for 3-4 hundred?? What would be done and would it be a regular automatic (meaning not having to shift from 1st, 2nd so on. Or could I just put it in drive and it shift by itself??
Old Aug 7, 2010 | 12:22 AM
85e150's Avatar
85e150
You would be buying a used transmission, which may or may not work, thus the comment about doing it several times. You would not be putting in an auto trans column, nor would you swap to a set of auto pedals, so you'd have a clutch pedal there, and an adapted shifter. If it worked, it would shift by itself.
You are buying a truck, right? Buy one with an automatic.
Aydanbilyeu
1966 - 1977 Early Broncos
May 20, 2015 04:14 PM
Flurgess
Feb 17, 2015 11:42 AM
hugo_7
Engine Swaps
May 9, 2014 09:26 AM
fzeed
Nov 15, 2008 04:25 AM
