Will This Bellhousing Work
Old Aug 6, 2010 | 11:29 AM
turbochargedford's Avatar
turbochargedford
I have a t10 and a t5 trans. a local guy has a bellhousing off a factory 80's f150 manual trans that was on a 302. he said it was a cast bellhousing. is it worth my time to drive an hour away to check or is it unlikely. i dont have the t10 handy to bring it along.
does anybody know what bellhousings are inter-changeible?
I thought the t5 and the toploader are the same but the t10 and the toploader were dif. i dont know.
Old Aug 7, 2010 | 12:27 AM
85e150's Avatar
85e150
T10 has GM and Ford CAR applications.
Toploader has Ford car applications as originally installed, but an OD version exists that was put in trucks. The input shaft length MAY be different than the car versions.
T5 Ford car application has a much longer input shaft, requires machining or an adaptor.
Ford bells differ in depth about 1/2" iirc between car and truck bells.
Can he read you the casting number and any other numbers off that bell?
Info here:
Well, limited bell info:
Bellhousing ID Chart
T5 people here, have the adaptor if you go that way. No heavy loads or towing....:
Modern Driveline - T5 / TREMEC TKO Transmission Conversion - 5 speed & 6 speed solutions to swap your Ford Mustang, Falcon, Cobra, Hotrod into Overdrive! Performance Parts
ALL AMERICAN BOY
17
Jan 18, 2013 06:11 PM
retrosixty6
Mar 30, 2011 05:51 PM
ChucksFordTruck
Apr 2, 2008 03:18 PM
pntrbl
Nov 14, 2005 11:19 PM
jgalloway1
Nov 7, 2005 04:59 PM
