351M a Big Block?
Old Feb 25, 2003 | 04:59 PM
Bill_Beyer's Avatar
Bill_Beyer
351M a Big Block?
Originally posted by BBBTruck
I agree, big block and small block are GM terms, however I always have discerned the two by the main bearings. Deck height, bore spacing, trans configurations will change within engine families, hence a poor way to categorize. It seems to be consistant that those engines where the main caps are exposed below the bottom of the block are small blocks and those webbed up inside the block are big blocks. The 335 series caps are exposed. To me, its a small block if you wish to use those terms.
The 429/460 main caps are exposed as well.
Old Feb 25, 2003 | 08:47 PM
BBBTruck's Avatar
BBBTruck
351M a Big Block?
seems im mistaken, i was looking at FE's and the 534 family
my lack of experience with the 385s should have told me to keep my mouth shut
Old Feb 27, 2003 | 04:29 AM
fordmando's Avatar
fordmando
351M a Big Block?
I think having the webbed main bearing caps would indicate the V8 in question was designed a REALLY long time ago (FE, Y-block) rather than merely a long time ago (Windsor, 335, and 385 series) as the "newer, lighter" V8's were designed without webbed main caps.
As to the big block/small block question, that question applies to Chevys, not Fords.
Old Feb 27, 2003 | 01:30 PM
GT40man's Avatar
GT40man
351M a Big Block?
the nice thing about my 400, is i get to call it a cleveland. the ricers want to see under the hood, right on the air cleaner it says 351-4v premium fuel. its at this time i learn if i got them beat. they usually say, look at the pretty windsor.
well its been a few months, and they now know its a cleveland, and they dont want none, as do some of the chebbie lt/ls 1 guys.
should i tell them its a 400?
Old Mar 21, 2003 | 10:47 PM
1979f_100's Avatar
1979f_100
351M a Big Block?
Would a 351m be considered a big or small block. What is the difference between this a 351 a 351c, 351w, and 400m?
Old Mar 22, 2003 | 03:34 AM
GT40man's Avatar
GT40man
351M a Big Block?
ok, i give. rather than abuse this like usual, ill be nice and honest. well sort of.....
big block and samll block are terms used to denote GM (aka chebby) engines. ford has always used the term "engine family" to denote its engines.
since i could go on and on over these terms and intems, ill be breif.
the windsor family, as noted above is the 220/260/286/302/351 engines. commonly denoted by some ford and all non ford people as small block ford.
the 385 family, as noted above 370/385/429/460 engines. commonly denoted by some ford and all non ford people as big block ford.
the 335 family, as noted above 351c/351m/400 engines. this is where the fun begins. it has the same bore spacing as the windsor family, the heads can be used on the windsor family. so you can call it a small block. the bell housing pattern is the same as a 385 family block, the block size is larger than a windsor, yet smaller than a 385, but can be called a big block.
so now having informed you of the facts, is it a big block or a small block. if this was mcdonalds, you have a small fry, a large fry, and something inbetween, a medium fry.
since this topic has been so overdebated, i really dont think it matters much to most of us, just stop calling by chebby terms.
Old Mar 28, 2003 | 07:42 PM
jginva's Avatar
jginva
351M a Big Block?
The <a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/">351w </a></a></a></a>is a taller version of the <a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/">302 </a></a></a></a>engine which has a 3-1/2" stroke. All 3 of the 351's have the same bore, bore spacing and stroke. It has the same main journal size as the 351M, but has the small bolt pattern of the 302.
The <a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/">351c </a></a></a></a> shares the same small bolt pattern as the 351W, but has 2-3/4" mains, and different design heads.
The <a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/">351m </a></a></a></a>is a destroked 400. Except for it's 1" taller deck height, its large 429/<a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/">460 </a></a></a></a>bolt pattern, and 3" mains, and it's larger #1 cam bearing, it shares the same design as the 351C. It is virtually identical to the 400, except different crankshaft and pistons.
All of these engines have enough differences in size or design between them to keep you from easily swapping parts directly from one to the other. Having said that, none of these engines are so different, that with some strong desire and good old fashioned ingenuity, that any of their parts could be swapped between all of them. That's what makes these engines so interesting and challenging.
Old Mar 29, 2003 | 10:06 PM
Matts72's Avatar
Matts72
351M a Big Block?
Actually I think the FE and 385's would be a large fry and the Wheezers would be a small fry and the 335's would be a small fry container with the same amount of fries as the large fry. it made sense in my head but typing may have screwed it up.
I think that the 400 and <a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/">351c </a></a>made excellent power but what the heck happened to the 351M. I picked up this one for $200 and it makes 140HP and gets a measly 8 MPG. I thought this was supposed to be a smog engine that got good mileage. I had a <a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/">429 </a></a>CJ that made 450HP and got close to 18 MPG. I guess I can't figure out why fewer cubes = poopy mileage. I don't know anybody that gets any better mileage. Somebody help
Old Mar 30, 2003 | 04:59 AM
pfogle's Avatar
pfogle
351M a Big Block?
mileage is all in the power, your <a href="http://www.motorhaven.com/">351m </a>only has 140hp so it's realy straining if it's in a truck, should have gobs of torque tho. you can get some bolt ons for that motor and make it a little better, but you really need to add about 100hp to it. that or convert it it EFI.
olblue77
May 31, 2016 04:43 AM
atomicjoe23
Jan 5, 2012 03:39 PM
89ford73
Sep 15, 2007 04:02 PM
sdloe
Apr 4, 2007 08:21 AM
canadianfordman
May 10, 2002 05:44 PM
