"Non-serviceable" Plug Question
Old Aug 3, 2010 | 10:04 PM
UGA33's Avatar
UGA33
Diagnosed an 01 7.3L to be leaking from the non-serviceable plug. The truck was leaking so bad it blew enough oil out to shut the truck off. Added 3 gallons of oil and she fired up after a minute or two and I can see it leaking from the plug. Question is this. I have the kit from Ford that has o-rings for the discharge hoses and rear plug. I know International makes a kit to fix the non-serviceable because I have used it to repair an oil leak. Will one of those o-rings in Ford's kit work on the non-serviceable plug?
Old Aug 3, 2010 | 10:41 PM
USAF CCM's Avatar
USAF CCM
I can't speak about those sources but check out Guzzle's site here:
Replacement O-rings for Ford Diesel Engines
Hope this helps.
Old Aug 3, 2010 | 11:09 PM
SpringerPop's Avatar
SpringerPop
Guzzle (Bob) has a custom-made, longer replacement "non-serviceable" plug that has more threads if yours are messed up.
Very innovative piece, and will be a Godsend to those that have some stripped threads.
Remember, ALWAYS make sure that all threads are SPOTLESSLY clean and oil-free! Use lotsa' brake cleaner and Q-Tips!
Then, BE SURE to use the LocTite supplied, and give it 24 hours time to fully cure!
If you don't, you'll be re-visiting the job soon...
Sorry, but I'm not sure that the non-servicable o-ring is the same size as the others, which are AS568A-906's in Viton90 material.
Bob will know for sure, and he'll be along any time now to let you know (unless he took the "long way home" from RRE).
Pop
Old Aug 4, 2010 | 08:48 AM
machmedic's Avatar
machmedic
The kit from International also has the plug with the longer threads.
Old Aug 4, 2010 | 11:31 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Give Guzzle a call and he will get you set up.
Old Aug 4, 2010 | 12:51 PM
UGA33's Avatar
UGA33
Sent Guzzle an order for it at 6:30 a.m. EST this morning. Really need it to show up by Saturday or it will ruin a man's camping trip.
Old Aug 4, 2010 | 01:50 PM
megawatt00's Avatar
megawatt00
Bob was sending product out from the post office at RRE....... And he was on vacation!! Now that is customer service!!!
Old Aug 4, 2010 | 06:10 PM
DieselOrings's Avatar
DieselOrings
SPONSOR
Jim, If that was a vacation, I need a vacation to recover from my vacation.
Josh, It all went out today and you should see it on Friday. The problem that you will have is adhering to the 24hr cure time for the loctite on the plug. If you try and get by with a shorter time, you run the risk of developing another leak on the plug down the road.
__________________
Specializing in Viton® o-rings and leak repair kits for the 7.3L and 6.0L diesels
(970) 368-4455 aka guzzle
guzzle's Mods & Maintenance website
Old Aug 4, 2010 | 06:18 PM
big poppa's Avatar
big poppa
I purchased that upgraded plug and HPOP gasket when I bought my o-ring mechanics kit from Bob just in case. I think every glove box needs one of those kits, you just never know. All, right, done my rambling. Good going, you'll be on the road in no time.
Old Aug 4, 2010 | 08:07 PM
UGA33's Avatar
UGA33
He is leaving out early Mon morning and that 24hr cure time will be well adhered to. I told him he has to let it sit for a day. He doesn't have a problem with it as long as his 7.3L is pulling a camper Monday morning. Thanks Bob for your wonderful products and customer service
fridgeddiesel
20
May 1, 2017 08:39 AM
GEugeneS
Nov 8, 2016 02:46 PM
Dukhunt22
Sep 30, 2016 10:28 AM
KelVarnson
84
Dec 5, 2012 02:59 PM
outdoormaniac
24
May 14, 2010 03:03 AM
