Brake cleaner
Old Nov 8, 2016 | 12:49 PM
GEugeneS's Avatar
GEugeneS
Brake cleaner
Will non-chlorinated brake parts clean damage the o rings on the HPOP quick disconnect hose fittings, IPR and non-serviceable plug?
Old Nov 8, 2016 | 01:58 PM
F250_'s Avatar
F250_
Brief contact (cleaning only) should not be a problem. Extended contact (soaking, etc.), though, is not recommended. Just wipe them down again with a light coat of engine oil after the contact and before reconnecting the fittings.
Old Nov 8, 2016 | 02:00 PM
GEugeneS's Avatar
GEugeneS
Thank you Pete
Old Nov 8, 2016 | 02:46 PM
F250_'s Avatar
F250_
I went through the same questioning back in the summer when I soaked both brand new serpentine and timing belts with engine oil on my daughter's Volvo. I was faced with either cleaning and re-using or replacing the oily belts with another set of brand new ones. The advice above is what I got as I sought input from both Volvo and Ford folks on multiple forums. I cleaned both with Dawn dishwashing detergent, rinsed them well, rinsed them off with Brakleen, dried them off really well, re-installed them, and there are no signs of any problem with either belt.
bigb56
May 23, 2012 10:14 PM
Greywolf
Garage & Workshop
32
Aug 13, 2010 01:35 PM
fordpride
21
Feb 21, 2010 10:59 AM
austinjorg
May 23, 2005 07:09 PM
88'7.3F-250
General Automotive Discussion
18
Apr 12, 2004 02:54 PM
