72 f250 360 starter problems
Old Feb 13, 2003 | 03:17 PM
greystoke33's Avatar
greystoke33
I've got a 72 f250 360 that I cant seem to get the starter lined up right for long anyhow. I have shimmed and shimmed, I can get it to line up, but after a time it becomes missalligned. Its not an everyday driver. I use it plow and pull out the neighbors that continually slide off our trail here. The starter ring seems to be in good shape, only one tooth missing on the whole thing! The starter is an after market. I was told that if i got an old original starter it might alleviate the problem. Any ideas!
Old Feb 13, 2003 | 05:31 PM
rebocardo's Avatar
rebocardo
On mine I found the problem was the bolts were getting loose, for whatever reason. What I did was get extra long bolts (5/16 coarse), shim them up with washers, and torque them down. Seems to be okay for now.
My Autozone starter aligned fine with my 390.
I think the cure is to get 5/16 bolts that are threaded all the way down the shank, grade 5+, that extend at least 3/8" past the bellhousing when everything is torqued down. There should be a washer and lock washer under the bolt head.
What I have thought of doing is using a grinding stone and grind just enough off the bellhousing to fit a (lock)nut and socket to the bolt end.
Old Feb 13, 2003 | 05:52 PM
jowilker's Avatar
jowilker
grey, How can a 3 bolt starter be misaleigned? Why are you having to shim it? You should stick the starter up run the three bolts in, fire it up and drive away.
Old Feb 14, 2003 | 08:21 AM
Freightrain's Avatar
Freightrain
Ya, this is NOT a chebby. NO need to shim anything. Time to put a standard, regular, off-the-shelf starter on it and FORGET IT.
That is the great thing about Fords, No problems putting any starter in any motor. Bolt it in and GO
Most of the time mine only have two (somtimes loose) bolts holding it in and it still works fine.
Larry
Old Feb 14, 2003 | 10:26 AM
BB's Avatar
BB
grey, are you running a motor plate between the engine and tranny?
Barry
Old Feb 14, 2003 | 08:18 PM
Like M. Fords's Avatar
Like M. Fords
One tooth missing, or four, I would still get the ring gear replaced before any more break-off. The starter gear is small, therefore few flywheel teeth make contact at one time. The teeth next to the broken one will be over-stressed and probably be the next to go before long.
What exactly is it doing to make you believe it is mis-alligned?
53pickemuptruck
19
Oct 26, 2014 06:56 PM
AZRRC
Jan 21, 2014 12:11 PM
Flughafen Leiter
Jul 27, 2012 06:19 PM
berlincam86
33
Feb 27, 2011 07:16 PM
mike99f350
Sep 17, 2007 04:49 PM
