6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Should the tailpipe be black?
Old Sep 2, 2010 | 08:45 PM
  #121
sdetweil's Avatar
sdetweil
Originally Posted by adamtheman16
I was staring down the exhaust pipe of an International with a 466 and DPF system on it the other day. I just noticed that the pipes were clean as could be, only water and rust on the inside of them. I could also see the backside of the DPF, and it looked brand new. Not even gray. Nice creamy white color. The truck had over 50,000 miles on it. That is what I expect from a stringent emission control of particulate matter. Black soot is particulate matter right? Or am I getting something wrong?
that is exactly it!.. guck on the inside, clean on the outside
Sam
Old Sep 2, 2010 | 08:46 PM
  #122
sdetweil's Avatar
sdetweil
and my exhaust tips are almost clean already.. not black like before..
the dealer ended up calling the hotline, cause they couldn't figure it out..
the hotline said r&r the DPF.
Sam
Old Sep 7, 2010 | 07:57 PM
  #123
ChargersFanInCO's Avatar
ChargersFanInCO
Originally Posted by sdetweil
so, whats the best/easiest way to clean the tailpipes so I can check for black ?
sam
I let it cool off today when I got home, sprayed some brake cleaner up in there and used a clean rag. They look brand new. I had some soot, but I've been running it REALLY hard for the last two weeks. Will go back to a normal routine starting tomorrow and will see what happens. I'll take a new DPF.
Old Sep 9, 2010 | 06:29 PM
  #124
vloney's Avatar
vloney
I watch these threads constantly because inevitably someone posts something, and later they end up in my bay. Got one here now from Colorado curiously, just had a DPF replaced (Must be one of the "good" dealerships). 2000 miles later, "Customer said that it started blowing black smoke, and quit going down the road". HMMM......... No oil touching the stick, DPF plugged solid, no exhaust at all coming out of the pipes. Removed the dpf, starts and runs but smokes and stinks like overfueling. SOOO, FTE, be a "GOOD" Ford tech and replace the dpf again and pronounce it fixed (let someone down the road worry about it), or pursue it farther and repair the reason the dpfs fail (this one is good, just plugged solid).
Old Sep 9, 2010 | 06:33 PM
  #125
sdetweil's Avatar
sdetweil
Fix it of course! Not a DPF problem.
Sam
Old Sep 9, 2010 | 06:34 PM
  #126
senix's Avatar
senix
there is no replacement for diagnostics.
Old Sep 9, 2010 | 06:48 PM
  #127
vloney's Avatar
vloney
Sam
The comments made by the Colorado dealership (on OASIS) shows its the same problem.
Old Sep 9, 2010 | 08:26 PM
  #128
sdetweil's Avatar
sdetweil
Bummer that THEY passed it on!
Sam
Old Sep 10, 2010 | 07:45 AM
  #129
vloney's Avatar
vloney
Passed on more than you know. Warranty problems now. Truck has 103 k miles on it. DPF was replaced at 98k. Ford will ask, "Was this the same issue?". It leaves it up to me to make the determination whether the customer pays or its warranty (another reason you don't **** off your tech). I backed off and let the powers that be hash it out to see who pays, then I'll get back to work. See what kind of a mess poor diagnostics leads to?
Old Sep 10, 2010 | 08:06 AM
  #130
sdetweil's Avatar
sdetweil
well, is it the diagnostics fault, or just sloppy (aka, incomplete) workmanship?
is the DPF clogged, yes
is there a way to 'unclog' it at the dealership, no
so it has to be replaced, yes
done
wait.. what CAUSED the clog. injector, ??
did the CUSTOMER cause it, no
was the original problem found (documented) inside warranty, yes
was the original problem completely diagnosed inside warranty, no
is that the customers fault, no.
I think it should be easy for the 'powers' to make this kind of decision.
Sam
Old Sep 12, 2010 | 09:43 AM
  #131
John7894's Avatar
John7894
Thanks for the update. Mine will go to the dealer week after next. I need to get something else lined up to drive while it's there...
What that really means is I need to buy 2 new batteries for my 7.3 so I can drive "Old Reliable" while the 6.4 is in the shop...
Old Sep 13, 2010 | 03:57 PM
  #132
vloney's Avatar
vloney
drained a gallon of oil out of the CAC, a pint out of the downpipe, yeah, just replace the DPF!
Old Sep 13, 2010 | 03:58 PM
  #133
senix's Avatar
senix
That one has some big problems...well maybe not anymore.
Old Sep 13, 2010 | 04:56 PM
  #134
John7894's Avatar
John7894
Did the CAC boots show any sign of oil seepage?
Old Sep 13, 2010 | 04:58 PM
  #135
vloney's Avatar
vloney
Nope, water......uh, oil tight!
