Help outer U -joint
Old Aug 1, 2010 | 05:42 PM
Jim Hunt's Avatar
Jim Hunt
Help outer U -joint
how the hell do I get the u joint to come out took hub all off and snap rings off of caps but still can not figure it out D-50 96 250 4x4
Old Aug 1, 2010 | 05:53 PM
redman84's Avatar
redman84
Take the spindle off and pull it out of the d50. If it's the passenger side there is a rubber boot on the shaft. I think you may have to take the clamp off of that boot then pull.
Old Aug 1, 2010 | 06:55 PM
Jim Hunt's Avatar
Jim Hunt
then what
still pounding btw
sore fingers and need more beer
Old Aug 1, 2010 | 07:03 PM
redman84's Avatar
redman84
Well with the D 50 once you pull on the stub it should come out of the pumpkin leaving you with a wimpy little axle shaft that has a u joint in it. I don't know if there's a way to change the joint with it in the diff. When I pulled mine out it was pretty easy to get em out and changed(mostly because I took the two shafts to a machine shop and had them press out and in the joints for me!) But I figure even if you wanna do it yourself it is still easier. Put the shaft in a vice or get a big c clamp and the right sized socket and push that old joint out.
JDC1
2004 - 2008 F150
Apr 15, 2010 10:27 AM
gene17847
Jul 29, 2008 10:28 PM
Dan Taylor
Jul 18, 2008 02:18 PM
40LUTZAG
1997 - 2003 F150
Apr 16, 2008 02:57 PM
1999F250
Jun 1, 2005 04:54 PM
