another EOT ?
Old Aug 1, 2010 | 11:47 AM
havns3's Avatar
havns3
another EOT ?
i fianilly got to spend some driving time last night with the edge insight working. here is the readings i got:
outside air temp about 85-90.
55 mph= a 28 degree separation ECT=185 EOT=213-215 range
60 mph= around a 30 degree sep
65 mph=35 to 40 degree separation
EOT would qiuckly cool down when slowed down to go through towns
later on i programmed the rpm to moniter beside the temps
it looks like i can figure on a idle temp seperation of 22 to 25 degree between ECT and EOT
the separation increased by about 2 to 3 degrees for every 250 RPM's of enigine speed .
the highest oil reading i got was 223. coolant temp was 190-193.
most of my driving is at 55-60 mph .ECT runs between 180-185 . so this should make my EOT run 210- 215.
what kind of temps are you all seeing before the Coolers fail? I need to make it aleast another 2-3 months before i can afford to fix this oil cooler add the coolant filter and the egr cooler.
Old Aug 1, 2010 | 12:08 PM
sammy77's Avatar
sammy77
Those numbers are definetley not good. Anymore than a 15 degree spread between the two is trouble. How long...who knows?? If you can't do the coolers now I suggest doin a major coolant flush. It may not help much though... My opinion, park the truck before it costs you alot more.
Old Aug 1, 2010 | 03:43 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Those numbers sound way to high by what ive learned here
the highest insite reading on my 05 ex 6.0 was eot 205 & ect 200. 95 degee's in mn not towing.
Old Aug 1, 2010 | 05:51 PM
texans's Avatar
texans
Originally Posted by sammy77
Those numbers are definetley not good. Anymore than a 15 degree spread between the two is trouble. How long...who knows?? If you can't do the coolers know I suggest doin a major coolant flush. It may not help much though... My opinion, park the truck before it costs you alot more.
I agree with you
Old Aug 1, 2010 | 06:04 PM
az4x4bronc's Avatar
az4x4bronc
ECT 180-185 sounds low. You should make sure your guages are reading correct.
Old Aug 1, 2010 | 06:17 PM
69cj's Avatar
69cj
Agreed, ect should be between 195 and 205. Sometimes higher depending on conditions. However the spreads are still disheartening and predict future failure.
Old Aug 1, 2010 | 08:41 PM
98SurplusExpy's Avatar
98SurplusExpy
Oil cooler time ... welcome to the glorious quality & engineering of the International 6.0L.
Old Aug 1, 2010 | 10:05 PM
havns3's Avatar
havns3
i am planning on changing out the cooler in about two weeks. just have to try to limp it through. i was wondering about that ECT temp too. i am wondering if the thermo stat is in or froze open. truck does warm up quick though but i have had the insight since thursday night and yet to see a temp over 190. i was really hoping i would have to join the cooler club so fast after purchase but that is what i get for buying a 6.0 without researching first. but i like the truck and it has a lot of power for stock. now how do i break the news to my wife?
Old Aug 2, 2010 | 09:11 AM
helilog56's Avatar
helilog56
I had readings like that with ECT.....required a t-stat change !
Excurvelle
Oct 19, 2014 08:36 PM
BryanStein
May 29, 2014 10:09 PM
Weld2
May 15, 2013 07:32 AM
egregg57
Dec 3, 2012 10:29 PM
Super Duty Daddy
Mar 18, 2012 11:38 AM
