Would you recommend SOLID U-Joints?
Old Jul 31, 2010 | 11:30 PM
fish_bulb's Avatar
fish_bulb
I have '73 F100 with a big block that I primarily use for sand dunes. It seems that every dune trip I end up breaking a u-joint in the front D44. It's usually caused by a cap cracking. I only use the Dana/Spicer joints, but they still break on me. A few companies like Yukon, CTM and OX make solid u-joints, that don't have rollers and are said to be really strong. That might solve my problem, but I don't know if they are only intended for rock crawling/slow speed (low friction, low heat) applications or if they would work for my type of wheeling too.
Is anybody using these? Think they'll solve my problem.
Thanks!
Ben
Old Aug 1, 2010 | 12:23 PM
Ford_Six's Avatar
Ford_Six
They should work if you use a moly-graphite grease in them and maintain them properly. You really should replace the axle shafts as well, since they typically get damaged by a trashed universal and can cause later joints to fail much sooner than they should.
Old Aug 6, 2010 | 03:39 AM
NavyMIDN08's Avatar
NavyMIDN08
Most systems have some sort of engineered weak spot. If its your u-joints that fail now and you upgrade to bulletproof solid pieces, then your weak link may end up being your axle shaft, driveshaft, transmission input or output shaft, or a whole host of other bigger, more expensive parts. I use cheap u-joints so I can keep a stock of them in the truck. That way I can control what part breaks when I'm out having fun. That way i'm more confident I won't snap another axle shaft, locking hub, or driveshaft. If you can count on your u-joints failing, it sounds like you have a well engineered truck, IMO
Old Aug 6, 2010 | 10:06 AM
mark a.'s Avatar
mark a.
If just the cap cracked that would have nothing to do with the strength of the u joint body.The grease hole through the u joint has nothing to do with your problem. I'd start looking into getting a Dana 60.
kruc
Sep 13, 2016 09:42 PM
Scotty's 52 F3
Oct 25, 2015 01:20 AM
ewelling
15
Oct 5, 2011 06:47 PM
SHOpar
Jun 21, 2009 10:32 AM
Gearheadjo
Nov 16, 2006 06:12 PM
