Sponsored by: Auxito
Though I had the problem fixed!
Old Jul 31, 2010 | 06:27 PM
Greenheadkiller's Avatar
Greenheadkiller
Was having oil pressure issues. So I dropped the pan and cleaned it out which had about 2" of sluged at the bottom and cleaned the pick up tube screen and put a new oil pump in. Have been driving it now for about 2 weeks and this morning when I got off the express was and stopped at the light the oil gauge bottomed out and the oil light came on, and then came back up. and it did it again on my way to work tonight when I stopped at the light. I am going to change the oil pressure sensor and see if that helps, If not it looks like I and going to have to rebuild the motor. 98 4.2 V 6 with 287.xxx miles
Old Jul 31, 2010 | 10:06 PM
steve(ill)'s Avatar
steve(ill)
the pressure sensor is an on- off switch that closes at 8 pis. if you have 5-6 psi at ilde, it will turn the light on. only a real gauge will show you exactly what you got.
kxw2x2
Dec 4, 2013 03:57 PM
Brygy
Aug 16, 2012 03:30 PM
2011screw
6.7L Power Stroke Diesel
22
Jan 16, 2012 04:25 PM
Randy 37
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Mar 17, 2006 01:02 AM
Rusting Bucket
1978 - 1996 Big Bronco
Nov 16, 2003 06:14 PM
