360 timing
Old Jul 29, 2010 | 05:39 PM
juchertf100's Avatar
juchertf100
360 timing
i just rebuilt my 2bbl carb on and truck is running better but just seems to be a little slugish on take off im thinking the timing is off a bit ,ive always set by ear, i wondering can someone tell me the proper way to set the timming with a light and vacume gage ,i have them just never used them ....
1974 360 4X4 automatic
thanx guys
Old Jul 29, 2010 | 05:58 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Timing light: black wire to ground and clip the pick-up on the #1 spark plug wire (first cylinder on passenger side)
Vacuum gauge: use a full manifold vacuum, either a port on the intake manifold itself or tee into an existing vacuum line such as: transmission modulator line, power brake booster.
Set timing with vacuum advance disconnected and plugged. Set to around 10-14 degrees BTDC.
Reconnect vacuum line and adjust idle.
Josh
Old Jul 30, 2010 | 09:12 AM
dhobdey1's Avatar
dhobdey1
do you disconnect the vacuum line off of the front of the carburetor and then plug the hose you disconnected and leave the carburetor port open?
Old Jul 30, 2010 | 05:31 PM
Bullitt390's Avatar
Bullitt390
Disconnect it at the distributor vacuum advance can and then plug the rubber vacuum line, I use a golf tee, works perfect.
Josh
chiefsfootball
Mar 2, 2015 06:34 PM
grsymy
Apr 13, 2010 03:06 PM
freightshaker69
Dec 6, 2009 08:50 PM
pintoches
Sep 30, 2007 08:38 PM
jpb222
Jan 27, 2004 07:06 PM
