Manifold
Old Nov 25, 2009 | 09:48 PM
freightshaker69's Avatar
freightshaker69
Manifold
i got this off a motor that was siting at my friends house i just going to ask don't know if its a 360 or a 390 if its a 390 will manifold fit on the 360 its a 4bbl manifold looks to be the same as mine i got a 360 its in reel good cond thanks for your time
Old Nov 26, 2009 | 01:20 AM
kenjh's Avatar
kenjh
it will fit ,352,390,428 will all interchange most part is it cast iron or aluminium?
Old Dec 6, 2009 | 08:50 PM
zrxlover's Avatar
zrxlover
Yes a 352,360,390, intake should all interchange, depending on the heads you have. Look at the intake port size to head intake head size to see if they are compatible.If you could afford a aluminum intake it would be better for you, weight, installation and probably performance. It depends on what you are wanting out of your motor?There are a lot of dual plane intakes out there that are good and some single plane intakes, depending what you want. I run a Edelbrock 390 Street Master single plane and have not had any problems. But that is only my choice for that build, dual planes are very good for a lot of applications.Research and ask from experienced FE builders.
Nick-1973-ford
Apr 10, 2019 11:51 PM
supercabfreak
39
Feb 27, 2017 08:50 PM
76Super
Nov 16, 2016 07:41 AM
mattlundb911
Oct 8, 2005 09:31 PM
blatherskite
27
Oct 12, 2003 07:21 AM
