1972 360 fe timing
Old Mar 1, 2015 | 12:33 PM
chiefsfootball's Avatar
chiefsfootball
1972 360 fe timing
In my 360 I have a cloyes timing set. From what I understand these engines came timed 6* retarded but I now have the dots on the crank and cam lined straight up. It idles really slow and I notice I need to give it more gas when taking off. Anyone know the initial timing that would be good for it? It's a 4 speed if that matters. Thanks.
Old Mar 1, 2015 | 02:16 PM
HIO Silver's Avatar
HIO Silver
I have mine set at 10 btdc.
Old Mar 1, 2015 | 03:02 PM
Rasputin53's Avatar
Rasputin53
Figure 26 on page 08-06-14 of my 69 shop manual shows the timing marks and the cam pin in a straight line when assembled correctly.
Good info in this thread:
https://www.ford-trucks.com/forums/9...60-timing.html
Old Mar 2, 2015 | 03:59 PM
JEFFFAFA's Avatar
JEFFFAFA
Sounds to me like you are blending two things together. Ford did retard the "cam" timing on like the 460 2* to help with emissions. But on a FE engine line up the timing gears straight up. I think the crank/spark timing might have been 6* BEFORE Top Dead Center factory but it'll run better at Hio's 10* BTDC.
Old Mar 2, 2015 | 05:02 PM
351Cleveland C4's Avatar
351Cleveland C4
10 is good, I run 14 on my cleveland, but I'm on the edge of pinging.
Old Mar 2, 2015 | 05:07 PM
chiefsfootball
Alright. Thanks. I'm right past 10. Probably 11 or 12. But I have tried to take it down a little more and it doesn't like that. It bogs down.
Old Mar 2, 2015 | 05:40 PM
351Cleveland C4
Ignition timing has to be adjusted WITH idle speed and mixture to have the engine run properly.
Old Mar 2, 2015 | 06:34 PM
Tedster9's Avatar
Tedster9
And crank or initial timing is just a piece of the puzzle. Disconnect and plug vacuum advance. Stay out of the plane of the fan blades, but run the engine up in neutral with a timing light and observe the total mechanical advance. Note "when" it comes is well as how much, you'll want to see all of it (crank + mechanical) before 3000 RPM at least. Your distributor mechanical advance could easily be worn, sticking, not suited for your application, etc.
abyars111
Jul 17, 2013 08:33 PM
wild bill pbr
Jun 6, 2007 06:26 PM
mswift
May 30, 2006 04:30 PM
xman7896
Dec 10, 2003 07:53 PM
big block power
Nov 24, 2002 11:42 PM
