1986 f250 lift
I know its not ideal, but why is it more dangerous? One of the kits a friend got from a 4x4 shop wasn't much different. They didn't have any Polyurethane kits at the time. Some trucks use more of a T-shaped lift if the frame has pockets for them. The bolts were stronger than what came in there. I did add a large washer on top of the puck and on the bolt head due to the slight body rot.
There is ALOT of stuff I don't do anymore after learning things over the years.
ask Mr. Prodouc.......I mean Prozon of the offroad forum. I believe I once read a thread or something where he was talking about how his stock F350 was on 37" swampers....
And I don't even get how 33's barely fit on your 350??? I have 32's measured out to a precise 31 and 5/8's of an inch, and they fit in there fine, w/ plenty of room all around, cept they rub a bit on the sway bar and leaf springs at full turn.
And here is some wide 35s witch would rub the body with some flexing
on
35's won't fit a F250 with no lift?
I know it's a 96, but, the 80-86 trucks have more room in the wheelwells...
Or, how about 38.5's with a 3" body lift on what is more or less an 86 F350 with bagged out springs(TTB leaves, little lower than a stock 1 ton:
And for good measure, 33's on an 86 F250 with a 2" BL:
#28
#29
on
Rust happened, that was the previous owners fix for getting it through a safety...
The only tire contact is the springs at full lock on any of them, the only way around that is way more lift or backspacing than needed.
We won't mention that the 1 ton now rolls on 44's and needs a different set of wheels with more backspacing so I can get to full lock... LOL
tom6.9idi
09-04-2014 05:48 PM
Mustangking1
09-08-2013 03:02 PM
lilsmokey
06-26-2012 11:48 PM
91dirtydiesel
29
09-07-2010 10:47 PM
