390FE vs 400
Old Aug 1, 2010 | 12:53 AM
wyoming4x4's Avatar
wyoming4x4
I'm involved with some enginemaster stuff!
Originally Posted by garbz2
And it takes about 25 grand of custom work to get the power levels that are obtained in the engine masters competition. Plus they only have to do dyno pulls and hold together. Not live in an actual engine compartment. The issue is with the oiling system that just is horrible. Oil goes to the top end first then to the mains? What idiot engineer thought that up. This well removes any advantage the cleavland heads provide. Good breathing cant fix no oil at the mains.
I can also mount just about any transmission combo to the FE today including the C6, C4, AOD, or even a TKO Tremec.
Garbz
On the surviving part and $25000 I don't spend near that much on the 400's I've built. Most of mine are pumpgas motors that anyone can build. On the lubrication issue their are acouple of little tricks that anyone can do at you garage to remedy this problem. I'm not a rich guy and every dollar counts when spending my money just like you. My biggest problem with the FE's in machine shop world was border line machining and having to catch some of these hidden problems before it bit me in the wallet. I've built some Nice FE's and even just getting a tranny to bolt up true to the engine has been a trick on an occasion. had to pull torque converter and indicate to engine at crank and the do offset dowles to block to compensate for borderline machining. which was causing the tranny seal leaking issue. Customer didn't want to pay for this problem and was a pain in the but. About a $2800.00 engine. This paticular engine was just a truck engine and went through a lot of crap to keep the customer happy. I didn't make any money on this deal but customer happy. I lost my butt on the deal in time!!! I've had less problems with the newer engines but problems are still out their for any engine. I got out of the machining business yrs ago and just do my projects now and work in natural gas engines. It pays way better than any machine shop job. I know I'm gonna catch some flak but I've done some time with these engines and they made me a smarter builder and won't forget these lessons. FE good engine but better be sharp!!
jaygee15
Oct 4, 2016 09:37 PM
59 BL JNS
Jun 28, 2016 10:15 AM
greentruck72
25
Nov 20, 2015 07:24 AM
Blinker Fluid
Dec 20, 2012 01:41 PM
F100man
Sep 20, 2010 07:06 PM
