Sponsored by: Real Truck
Problems with 6.0 P2290
Old Jul 28, 2010 | 02:37 PM
tim113's Avatar
tim113
So i gave up and thought i would take the Ex to the dealership to have my problem diagnosed. Keep getting a CEL P2290... Any way fixed the STC fitting on the HPOP and then began getting the code... The dealership called today and said that they needed to start looking for an electrical problem... Anyone ever heard of an electrical problem leading to this code with the 6.0? I changed the IPR and ICP because i knew they could be culprits... could not find a leak with an air pressure test. I don't want to get into a situation that we start hoping for a fix or not knowing what to look for... I do most of the work on my vehicles myself and have had bad experiences with dealerships in the past... The code only came on when hauling a 32 foot travel trailer or at high acceleration or going up a bridge...
Old Jul 28, 2010 | 04:53 PM
bpounds's Avatar
bpounds
This would be a good question to take to the 6.0 engine forum. You've already done the obvious in changing the ICP sensor and the IPR. I know a bad connector has been known to cause that fault, but you will get more expert help over in that forum. Make sure to note what year you have.
Rengland2008
Jun 21, 2016 08:46 AM
Oryo
May 10, 2016 08:59 PM
046.0
Jan 6, 2016 06:23 AM
thebrewguy
Sep 14, 2015 09:09 AM
farmboy1227
Aug 16, 2015 10:25 AM
