E4OD Fluid Level
Old Jul 27, 2010 | 07:23 PM
mdula's Avatar
mdula
E4OD Fluid Level
I know that this question sounds really simple but When checking the fluid level hot in park, it seems to "scrape up on the dipstick" and the fluid level looks to be overfilled...like 3, 4 times over the full mark.
I just bought the truck and notice an extra quart of fluid in the floor boards, and an empty quart in the bed.... Im concerned about the trans. If it was that overfilled wouldnt it be foamy and spew out??
Transmission also seems to rattle at the torque converter when idling. Truck drives ok, if I floor it in 1st the truck shudders like hell but pulls like no other..Cant tell if the wheels are hopping or if the trans is shuddering.
Old Jul 27, 2010 | 09:38 PM
mdula's Avatar
mdula
Well, turns out its just over filled. I drained some fluid out of the cooler lines untill it was belew the fill line...then I just added new fluid to level.
Still shudders but I dont hear the torque converter clanging like I did earlier. I just bought this pickp and im super paranoid the owner was hiding issues.
Old Jul 27, 2010 | 09:54 PM
raystankewitz's Avatar
raystankewitz
The rattle at the torque converter could be loose torque converter mounting nuts. You'll need to take the inspection cover off of the front of the transmission (bottom, by the oil pan) and check them. Total of 4, FYI. You'll want to turn the engine over by hand while doing this. Torque is 20-30 ft/lbs.
Don't know what to say about the problems you're having on acceleration, though. Would be good to know if you're having 'axle hop' or if there is a problem in the trans. If it was the forward clutch pack going south, seems like it would slip worse in 2 or 3, not 1. Maybe have someone watch while you 'mat it' a few times to see if the axle is 'tramping' on you.
HTH,
Ray
Old Jul 28, 2010 | 08:27 AM
mdula's Avatar
mdula
HTH,
Ray
Thanks for the response Ray. Yeah thats a good idea...just have someone look while I punch it lol, trying not to **** off the neighbors all the time. I went to inspect the torque converter last night and the exhaust crossover is right in the way of the cover...So I need to remove the exhaust, and those bolts look really bad.
I think it might be just wheel hop, come to think of it on turns It wont do it, just peel rubber.
rob_jones
Aug 9, 2015 01:11 AM
Reed
Aug 3, 2013 05:34 PM
richdawg
Oct 27, 2012 06:05 PM
Boz86
Mar 11, 2009 04:55 PM
ERIC79XLT
Jan 5, 2004 12:07 PM
