problem after overfilling e4od?
Old Mar 10, 2009 | 08:08 PM
Boz86's Avatar
Boz86
Looks like I overfilled my tranny by at least a quart.
How concerned should I be?
Old Mar 10, 2009 | 08:14 PM
fkaster01's Avatar
fkaster01
you should drain a quart out... the trans builds pressure, too much fluid equals too much pressure, equals bad things in your future
Old Mar 10, 2009 | 08:35 PM
Boz86's Avatar
Boz86
Crud, was afraid there was going to be a good reason to fix my mistake. Wish there was a drain plug to make this a little easier.
Old Mar 10, 2009 | 09:57 PM
anojones's Avatar
anojones
Is there any reason you couldn't use a oil extractor like the Amazon.com: Mityvac 7400 7.3 Liter Fluid Evacuator: Automotive or a Quick, Easy & Clean Oil Changes with PELA Products to do tranny oil changes? It would sure seem easier and can be used for oil changes in other vehicles you might have that are harder to crawl under than a full size truck.
Old Mar 10, 2009 | 10:03 PM
FourWheel's Avatar
FourWheel
Last time i overfilled a tranny i use a drill powered pump from walmart but u can use just about anything that will create a suction or u can just siphon it out but be carefull not to swallow tranny fluid and yes overfilling is not good at all i have blown a tranny because of this get it out as soon as possible
Old Mar 10, 2009 | 10:14 PM
Beastly's Avatar
Beastly
My local jiffy lube has a vacuum tool they put down my filler tube when mine was overful. You could probably do the same with a drill pump.
(edit: Note to self: When replying to a post, don't leave it open for over an hour before clicking 'post', without refreshing first. Makes self look dumb when the two posts before your own say the same thing.)
Old Mar 11, 2009 | 04:30 PM
fkaster01's Avatar
fkaster01
i've heard of a kit you can buy to put a drain plug in the pan on your trans... not seen one yet but someone at work said he did it to his chevy and its very simple to do... may look into that also
Old Mar 11, 2009 | 04:55 PM
White 97 xlt's Avatar
White 97 xlt
An easy way that requires minimum tools is to loosen one of the trans cooler lines, then start it up and let the line "leak" into a drain pan.. If you have an aux. cooler you should be able to just loosen the clamp on the rubber hose and slide the hose off the line, might get a little messy but it is CHEAP!!!!
alchemist1
May 5, 2014 06:02 AM
richdawg
Oct 27, 2012 06:05 PM
jason86
33
May 7, 2010 01:32 AM
kmbarr100
Jan 8, 2005 11:17 AM
Bubba Shrimp
Aug 14, 2003 07:24 AM
