Steering shaft problem
Old Jul 27, 2010 | 12:39 PM
91B's Avatar
91B
Hey Ford Fans got a question for you.
1975 F250 4x4 w/ 390, 4 sp manual, NP205
When I bought the truck it had an after market Grant steering wheel installed and it seems to work fine except for it can pull up/out about 4 inches! Upon examining the engine compartment it seems there is a slip joint that slides open when you pull up on the steering wheel.
The slip joint is located between two u-joints in a center section of the shaft. Now I was told that my truck has after market u-joints on the steering (Borgeson) so I was questioning if This slip-joint is an original piece and should be moving like this (I'm sure that my steering shaft shouldn't slide out 4 inches!)
The solution suggested to me for safety was to drill a hole into the shaft and put a grade 8 5/16 bolt in. just want to know if this will cause any issues or if there is supposed to be play?
Thanks ford fans.
Old Jul 27, 2010 | 04:31 PM
dynamic's Avatar
dynamic
I beleive that your problem is a missing C clip. Someone else will be able to bring up a drawing of the steering columns to confirm. Their should be a clip that holds the column center shaft in place. Its been a while but I beleive that is the issue.
The Borgeson shaft is designed to slip like that for chassis flex and such. The fact that you can pull the steering wheel up makes me think its something missing inside your column!
Old Jul 27, 2010 | 05:49 PM
kendooley's Avatar
kendooley
If I remember right, it goes like this. If you take off the steering wheel, the steering shaft has a step in it that the upper bearing rests against. Then the bearing is held in place in the column by a snap ring on the steering shaft. The upper housing with the turn signal switch is held onto the steering column with a couple of t-head bolts and nuts. That snap ring sounds like what you're missing.
Old Jul 27, 2010 | 05:51 PM
kendooley's Avatar
kendooley
Oh yeah, you'll want to fix that before driving it anymore.
Old Jul 27, 2010 | 06:47 PM
91B's Avatar
91B
ok so do i try to find a clip and were? or do i just drill it and make it stay!!?
Your opinion?
its my daily driver and I need it
Old Jul 27, 2010 | 11:01 PM
650's Avatar
650
Your opinion?
You should just put a new clip in it, something about drilling it...
You should be able to find it here in the picture, LMC Truck Parts - Page 101
Good luck
Old Jul 27, 2010 | 11:27 PM
kendooley's Avatar
kendooley
You can get a new snap ring at a good hardware store, or auto parts store, or an assortment at Harbor Freight. There's nothing special about them. It's not Ford specific or anything.
Old Jul 31, 2010 | 10:19 AM
fordsrgrt's Avatar
fordsrgrt
did you check to see if the 2 bolts that hold the column to the bottom of the dash are tight?,that will allow you to pull the column up also,theres a cover on the bottom of the column that covers the bottom up, remove and check to see if the bolts are tight
Fish_Scientist
24
Jul 20, 2017 10:57 AM
stevebigos
Nov 17, 2013 09:17 AM
FordFanboy
Sep 30, 2013 02:31 PM
1983F1503004x4
Mar 5, 2013 11:57 AM
Argess
Sep 20, 2012 06:18 PM
