Part help
Old Jul 29, 2010 | 08:51 PM
Big_Dom's Avatar
Big_Dom
Part help
Ok, so I'm still just learning about parts and junk and I have some questions.
I have a 73 390, what parts could i get for it for cheap?
Can you get more power from putting on bigger/smaller heads?
Whats the max I could bore it without it being supersoniced (???i think thats the word???) and how much would it cost me?
And is it possible to swap out the three different grilles that came from factory?
Old Jul 29, 2010 | 09:04 PM
AntiHero55's Avatar
AntiHero55
the only question i have an answer to is the one about the grilles. all 73-79 grilles are interghangeable. you just need headlight buckets when going from round to square head lights and vise-versa...
Old Jul 29, 2010 | 11:18 PM
650's Avatar
650
What do you mean by what parts could you get for it for cheap, If you need the part you need the part.
Old Jul 29, 2010 | 11:26 PM
steponit's Avatar
steponit
The 390 in stock form is already a power house.
The cylinders can only hold so much air and fuel.
Fuel is not a problem
The only problem is AIR
That's why guys put turbochargers on their engines
First, are you POSITIVE that is a 390 and not a 360 ?
Did you check the number on the crankshft or measure the stroke?
Any performance parts can be found by googling Ford Motorsports or Ford Racing
And remember those engine used Premium fuel *98 Octane*
Unless you buy avgas where you going to fill it up ?
Old Jul 30, 2010 | 06:34 PM
HIO Silver's Avatar
HIO Silver
"Cheap" is a relative term. You didn't state your intended use for the engine and truck so I'll go with generalizations:
With that said, the engine is basically an air pump. The more air (and commensurate amount of fuel) and combustion efficiency will realize power gains.
IMO - Unless your end use is high RPM for which the 390 is not really intended, the least costly and easiest horsepower results from a 650 cfm 4 bbl, dual plane intake, and long tube headers. High RPM go with a 750 to 800 cfm 4 bbl on a single plane or high riser intake, and headers. Synthetic lubricants are worth a few HP. Let's call that Stage 1.
Stage 2: Camshaft + ported & polished heads or aftermarket aluminum heads.
Stage 2.5: Higher ratio rockers and aftermarket rockershafts.
Stage 3: 10:1 forged pistons, ARP hardware
Stage 3.5: Nitrous.
Stage 4: Survival Motorpsorts Stroker Kit.
Stage 5: Forced Induction (Turbo/supercharger)
Old Jul 30, 2010 | 06:56 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
There is no higher ratio rocker arms, adjustable rockers are 1.76, non adjustables are 1.73. In essense, not even the thickness of a fly's butt hair.
Although you have to be carefull buying after market rocker arms, some are 1.75 and some older Harland Sharps are 1.6.
Aftermarket shafts with end stands are just an excellent idea with FE engines, stock or hot, it makes good sense.
Josh
Old Jul 30, 2010 | 07:33 PM
Big_Dom's Avatar
Big_Dom
Stage 3.5: Nitrous.
Wow, thank you Silver! You gave me exactly what I needed. To be honest, I came in here not even really knowing want I wanted but you did a lot. Not just ideas but actual plan too. Thank again.
steponit
And my 390 is a 73, and the guy before me didnt say anything about high octane gas, and I've been just burning the cheapest I can get. If I have to I'll start using 98 but I'd like to be sure. So are you absolutely positive it needs 98oct?
Old Jul 30, 2010 | 11:26 PM
steponit's Avatar
steponit
My mistake ..sorry
I conferred with someone else, he said the 71 390 used regular gasoline so the 73 390 2v should be the same
There were different 390's
some used regular and some used premium
Check your compression ratio
Old Jul 31, 2010 | 11:11 AM
HIO Silver's Avatar
HIO Silver
Bullitt390 - Thanks for the details on rocker ratios.
BigDom - You're welcome. However, the progression of stages above is not a step-by-step plan because what upgrades/parts are done will affect the parts & specs that were done in the previous stage. For example, high compression pistons (>10:1) will likely be incompatible with forced induction systems so you might be ending up buying parts twice - not good if you're watching the budget. That's why I'm a big advocate for outlining the end use and overall vision for the vehicle in which the engine will be installed and then plotting a course (engine/suspension/brakes/conveniences) to reach the goal.
IMO, the best bang for the buck is the carb/cam/intake/headers combination. A well matched system will give you alot satisfaction in terms of driveability, use, and of course return on dollars spent. Nitrous (small shots!) systems can provide very good dollar-per-HP return.
