Compression Check Puzzler
Old Jul 27, 2010 | 10:02 AM
AbandonedBronco's Avatar
AbandonedBronco
Hi Everyone,
Was curious as to how my engine was doing and decided to run another compression check. Last time I did one a few years ago, it was great all across the board with a 5 - 6% variation. Everything still seems to be good, but oddly...one of the cylinders actually went up in compression. Way up.
Cyl:
1 165
2 163
3 158
4 161
5 180
6 165
I ran the test several times and came up with roughly the same numbers each time. Cylinder number 5 has greatly increased in psi since the last test I did (in which it was right in line with everything else.) Any ideas as to what would make a cylinders compression increase?
Not sure on this one...
Old Jul 27, 2010 | 11:23 AM
1986F150six's Avatar
1986F150six
Carbon build-up?
Old Jul 27, 2010 | 12:33 PM
F-250 restorer's Avatar
F-250 restorer
How did #5 plug look? Was there an oily spot on the end of the plug threads? Are you losing/burning any oil?
Could it be a bad valve seal? Had it been sitting for a long while when you checked it?
If you squirt a couple shots of oil in the others, do they come up to the same compression as #5?
Old Jul 27, 2010 | 12:38 PM
JimsRebel's Avatar
JimsRebel
Do a "leak down" compression check.
Old Jul 27, 2010 | 12:52 PM
200000+F150's Avatar
200000+F150
Originally Posted by 1986F150six
Carbon build-up?
That's a distinct possibility. Also, if possible, check the cam lobes for this cylinder compared to the others. A change in overall duration due to wear could theoretically cause higher cylinder pressures. Not really likely, but worth a look if you are concerned about it.
Old Jul 27, 2010 | 02:07 PM
91Bronc300's Avatar
91Bronc300
I would guess carbon buildup what with the carburetor issues you've been tackling
Old Jul 27, 2010 | 05:23 PM
dustybumpers's Avatar
dustybumpers
yup, and there you have it. plus the fact, how long did the truck sit before you started using it agin?
Old Jul 27, 2010 | 05:46 PM
AbandonedBronco
Thanks for the info everyone. The plugs looked perfectly fine and #5 wasn't the slightest bit different than the rest of the bunch.
Overall, the truck's never sat longer than a week in the last five or six years and I drive it every day. It sees a lot of long distance trips as well (just got back from a 300 mile round trip).
I did have a temporary carb on there that was very rich and fouled all my plugs up to the point of them needing replaced until I got my 390 put back on. Those were soot black.
What could I do to clean the carbon out? How do I check for a bad valve seal? I'll have to see about getting a leak down test done.
As far as the cam lobes being worn down. Quite possible. It's 30 years old and never been replaced.
Old Jul 27, 2010 | 07:24 PM
dustybumpers
well......... I am about to throw the spoon in the pot here, and all the .02's will come out, BUT, we used to hold the throttle open slightly, and pour a small stream of water down through the carb. keep it running while you do this, and it will smoke, butthe carbon is gone when done.
Old Jul 27, 2010 | 08:36 PM
F-250 restorer
What I want to know is how a carb could cause carbon build up IN ONE cylinder?
Old Jul 27, 2010 | 08:37 PM
F-250 restorer
Dusty's steam cleaning service! We used to do the same thing, only with ATF. Let's talk about smoke....
Old Jul 28, 2010 | 09:29 AM
200000+F150
My .02 is "been there, done that - works like a charm". You could try this and see if the pressures equalize after.
Old Jul 28, 2010 | 10:24 AM
Harte3's Avatar
Harte3
"Dusty's steam cleaning service!" Does he do carpets too?
Old Jul 28, 2010 | 11:16 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Not exactly for one cylinder, but there is discussion on the proper orientation in mounting the carb. With the primary throttle plates parallel to the head or not. On mine I mounted it with the primary fuel bowl facing the firewall. To mount parallel I would have had to cut off the bottom of linkage to clear the intake. It's all about flow distribution to the cylinders. Jury is still out on the subject. I haven't had a problem, but I've only got about 1,000 miles on it.
Old Jul 28, 2010 | 03:26 PM
AbandonedBronco
I'll have to try to clean out any carbon that may be built up. I also know I'm due for a cam replacement as I have no idea how many miles are on it (165k, 265k, or 365k?).
The Offenhauser DP intake makes it so you can only orient the carb one way.
Thunderhorn
1978 - 1996 Big Bronco
Oct 27, 2014 09:05 PM
Rusty_Old_F250
35
Apr 22, 2012 09:35 AM
cwlightning03
Sep 17, 2009 09:42 PM
PowerstrokeJunkie
43
Apr 30, 2008 04:50 AM
lost_in_space
16
Mar 5, 2005 05:03 PM
