48-50 F-1 Emergency Brake Setup
Old Jul 27, 2010 | 06:53 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Some time back there was a post with pictures of the emergency brake setup and now I can't find it. I thought I had saved the pictures because now I need to reassemble mine and I have no idea how it goes together. I've been looking at it for three days now and still can't figure it out. Can someone help?
Old Jul 27, 2010 | 07:28 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Is this what you need? Front is to the left
Old Jul 27, 2010 | 07:34 AM
GreatNorthWoods
Thanks Ross. That's exactly what I needed.
Old Jul 27, 2010 | 09:22 AM
firstrider's Avatar
firstrider
Will have the e-brake cable boots reproduced very soon . This is what they look like .
Old Jul 27, 2010 | 01:27 PM
GreatNorthWoods
Jeez, what a PITA...not one of Ford's better ideas!
BTW, I purchased a new "reproduction" E-brake cable from Macs and it's considerably different from my old one and far from a bolt in. I can use it but there's no way the retaining bracket that bolts to the frame on the bottom of the passenger side will work with it. I'll have to fabricate something. Anybody else run into that? I wonder if there were more than one style E-brake cable for 48-50 trucks? On my original one, the bracket clamped on the cable housing but the new one is much larger in diameter and won't fit in the bracket plus it needs a clip of some kind (sort of like a brake hose clip) to hold it...
Old Jul 28, 2010 | 10:46 PM
mclaughlinrp's Avatar
mclaughlinrp
Yes! I have run into the same thing. I even went so far as to buy another main cable from a different supplier because the picture was stock. It turned out to be the same black sheathed cable.
For now, I've left mine loose in the brackets on the rear and just pushed in as far as the flange on the front one. It works but is not right. My plan is to cut the flange off the main cable and make some sort of bushing for all three to make up the difference in size so the clamps will work.
I'm finding these kinds of issues with a lot of parts, most recently the floor seals not fitting around the column and pedals right, brake pads and speedometer cables with the wrong threads, a glove box spring without the proper bend in it and an exhaust crossover pipe that wouldn't clear the oil pan. Minor issues, but annoying nonetheless.
If anyone knows of a vendor who carries stock reproduction cables I would really appreciate the tip.
Old Jul 28, 2010 | 11:39 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You might try Antique Auto Supply, Arlington Texas. 1-817-275-2381. He has some alternate sources for many parts, and is great to deal with.
I think the source of the problem on these cables is that later model F-100's apparently have the exact same length cables, and used the same rear brakes, so someone decided they must be the same cables.
Old Jul 29, 2010 | 07:00 AM
GreatNorthWoods
Being a rodder for so many years and making parts designed for another application work is normal and I expect some fabrication...but, dang it, when you buy something "reproduction" that's supposed to bolt in and you still have to fabricate brackets and things to make it work, it seems like wasted time...
Old Jul 29, 2010 | 07:08 AM
49willard's Avatar
49willard
Vern,
Your experience makes me glad that I cleaned up and can reuse the original cables. I had thought about changing from the stock ebrake mechanism-handle in the cab to a foot operated setup. I may just stay stock!
Old Jul 29, 2010 | 07:14 AM
GreatNorthWoods
Originally Posted by 49willard
Vern,
Just for clarity here, we're talking about the cable that runs from the handle to that micky mouse bell crank contraption mounted to the crossmember behind the cab. I was also considering a non-stock E-brake but since all the original stuff was in such good shape (except the broken cable coming from the handle) I decided to go stock. Guess I should have gone wth my original plan...the dang cable was 50 bucks!
Old Jul 29, 2010 | 07:27 AM
49willard's Avatar
49willard
Vern
All of my cables are reuseable. The stock setup did work well back when Willard was my daily. Given that you need a cable going from the cab back to the bell crank mechaism. I would consider going with a foot operated setup.
Old Jul 29, 2010 | 08:11 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I thought you were talking about the two that go to the brake shoes.
Old Jul 29, 2010 | 07:56 PM
GreatNorthWoods
Those cables were in good shape and I'm using them with the Chevy 10 bolt.
Can someone remind me about the cable routing from the handle to the bell crank? I know it goes through the floor near the column and then over the transmission to the passenger side but I can't remember where that retaining bracket bolted to. Possibly the crossmember (which I removed to make room for my AOD)? It doesn't seem long enough to bolt to the right or bottom right frame rail.
Old Jul 29, 2010 | 09:41 PM
BlueOvalRage's Avatar
BlueOvalRage
Vern,
If memory serves, it bolted to the top of the transmission crossmember with two bolts. Can you make it stretch or add a bracket to bolt it to your new transmission crossmember?
Old Jul 30, 2010 | 01:41 AM
Julies Cool F1's Avatar
Julies Cool F1
There was a retaining clip bolted to the upper right "Clutch Cover" (the ring closest to the transmission) bolt then back to the transmission crossmember as Joe stated.
There are some pictures and text in this thread:
https://www.ford-trucks.com/forums/8...able-clip.html
