Hey everyone, haven't been on for a long time due to my truck being down since December and not having the funds to get her going again. Well i finally got her in the shop and the tranny out to replace the flexplate. Back in december my starter sheared the teeth off the flexplate. Now its time to find the fp and i'm wondering if it'd be the same as a 1990 C6 trans. Napa, oreilly's, autozone, etc. show N/A on the 1991 E4OD trans. But i can get one for a 1990 C6 for around $55! Thanks for the help guys!
Flywheel -
IMPORTANT. DO NOT USE 6.9 flywheel or vibration damper on 7.3 or vice versa. If components are intermixed, engine vibration and premature component wear may be encountered. For identification, compare these part numbers.
Vibration damper 6.9 1805414C1
Vibration damper 7.3 1809117C1
Flywheel Auto 6.9 1803219C1
Flywheel Auto 7.3 1809212C1
Flywheel manual 6.9 E7TA-6477-AB
Flywheel manual 7.3 E8TA-6477-AA
Ok, i found that the flexplate i was inquiring about is going to be the correct one, the only issue is it's not balanced, it doesnt come that way. Some of the flexplates for this motor/trans are balanced, some arent...am i going to run into issues with that and should it be balanced? Thanks guys!
