1966 - 1977 Early Broncos
Torque Converter/Flexplate Problem
Old May 28, 2011 | 10:17 PM
tomf1230's Avatar
tomf1230
I just installed my engine/trans/transfer case, & I'm having a problem. The 6 o'clock converter stud doesn't penetrate the flexplate so I can get a nut on it. The others I can see have at least 2 threads. To make matters worse, I can't turn the engine when it's mated to the trans (both turn when they're apart). I've pulled it apart & reseated it about 10 times now, & no luck. The engine is a 5.0l, trans is a C4. The flexplate is the recommended one from the vendor and it's not hitting the converter drain plug. Getting pretty aggravated on this one, since this setup (with stock flexplate) was bolted to a 302. Any ideas? Thanks in advance.
Old May 29, 2011 | 08:10 AM
chrlsful's Avatar
chrlsful
C4/5.0
Howdy!
AND welcome to the site! Lotta great guys here, lotta help. Also welcome to the forum. It seems to B one of the smaller, less active on FTE. For some great boots on the ground help I've joined my local chapter and see my neighbors that way. "Eyes on" could benifit. The contact is in FTE "table of contents" @ top of this page. Select "forums" scroll down to "chapters". Select yer state's name. Go 2 dat place.
To answ yer Q: no, no ideas. The later bronks came with a C4 specific to the vehicle, it wuz for a 302 and I got 1 of each on the acreage (Trouble is some 1 stole the Tq converter). U may NOT have these 2 babies, altho U got "reasonable facsimilies". I just don't know. Some 1 w/more knowledge will B along shortly. Keep talkin 2 us & we'll getja there, just may B not @ the speed you'd wish (like yesterday!). I been @ it w/this rig 28 yrs but I got no $, poor tools, low skills, etc.
Old May 29, 2011 | 02:40 PM
tomf1230's Avatar
tomf1230
Hey, thanks anyway. Think I'm going to post this in the F100 section for more visibility. This has me puzzled, & has stopped work on the Bronco.
Old May 29, 2011 | 06:42 PM
chrlsful's Avatar
chrlsful
Not sure thaqt will help...how bout an active bronk tech site? U go 2 CB yet?
Old May 29, 2011 | 09:09 PM
tomf1230's Avatar
tomf1230
Yes, I typically do, but I thought I might get some guys on here with some more generalized Ford knowledge. That's my next step if I can't get the vendor on the phone.
Old May 29, 2011 | 10:26 PM
JLKirby's Avatar
JLKirby
Flex plate
This is just something to think about.Did the engine you are installing have a manual transmission?If so did you remove the pilot bearing?
Old May 30, 2011 | 07:40 AM
tomf1230's Avatar
tomf1230
Gonna check for that today. I didn't think about that before, but I'm betting that's the problem.
Old May 31, 2011 | 06:26 AM
chrlsful's Avatar
chrlsful
vendor
Humm, vendor...what did U purchase? T%o best assist we may need lots more info.
Old May 31, 2011 | 11:56 PM
tomf1230's Avatar
tomf1230
Pilot was still in Oh well, lesson learned. Nothing appeared broken either, so I'm keeping my fingers crossed. Thanks!
Old Jun 1, 2011 | 06:43 AM
chrlsful's Avatar
chrlsful
Kirby n Tom don't NEED details!
Way ta go team!
Hope there's no other delays in gettin er done...
BTW: what x-fer case U use? How to mate to C4 (esp if not from a bronk).
Old Jun 1, 2011 | 07:24 AM
tomf1230's Avatar
tomf1230
I have a D20. It & the C4 came from a Bronco, so no issues there.
Old Jun 1, 2011 | 06:10 PM
chrlsful's Avatar
chrlsful
3 oh 2 VS 5 oh
Excellent, sounds like yer all set from here, as a "sixer" (till the day I die) no knowledge of 3 oh 2 v 5 oh.
mortenauthen
Jul 23, 2013 08:04 PM
tomf1230
15
May 31, 2011 11:46 PM
71dusterdan
Sep 28, 2009 07:22 PM
cjf5150
May 2, 2006 12:21 PM
86rustbucket
Feb 14, 2005 06:40 PM
