EGR DELETE KITS??
Old Jul 26, 2010 | 12:28 AM
scottman70's Avatar
scottman70
EGR DELETE KITS??
If I use the bulletproof EGR delete kit is there still a place to install the EGR valve so I can pass the visual emissions inspection here in AZ??? THey visually inspect looking for the EGR valve to be installed here in AZ? How can I get my EGR deleted but still pass this inspection??
BulletProofDiesel - Darn-Near Bullet Proof Diesel Products for your 6.0
Old Jul 26, 2010 | 05:37 AM
npccpartsman's Avatar
npccpartsman
From what I see with those kits they don't require removal of the EGR valve itself, so you should be OK. My 04 truck is done virtually the same way and my EGR valve is still in place.
Old Jul 26, 2010 | 07:46 AM
ehgeeray's Avatar
ehgeeray
Yep, I still have mine in place too. The kits come with a block off plate if you want to remove the EGR but you have the option to leave the EGR valve in place.
Old Jul 26, 2010 | 11:18 AM
canucklehead2004's Avatar
canucklehead2004
there are a couple of kits on ebay from river city diesel (i think is the name) for $200. I wish I'd seen theirs earlier, I could have saved $100 over the Sinister kit I bought.
Like others said, you can leave the valve on. the bypass pipe to replace the cooler is hard to see.
ALSO, cheezit, a Ford tech, posted some interesting findings he had when he put his valve back on. I'm putting my valve back in place.
Old Jul 26, 2010 | 05:26 PM
Young Gun's Avatar
Young Gun
The BPD kit does keep the EGR valve intact and in stock location.
Old Jul 26, 2010 | 06:50 PM
cheezit's Avatar
cheezit
I paid less for my sinister kit on ebay then $200.00
Old Jul 26, 2010 | 07:06 PM
canucklehead2004
wuuuu? how'd you do that? They were $300 or best offer, and the lowest they'd go was $285, and i bought mine about 1-2 months ago from Ebay.
Hey Cheezit, for the purpose of replacing my EGR valve to plug in and hopefully make fan work, do I have to get a specific EGR valve for my 2005 model year, or will any EGR valve work (from '03-07??) ? Mechanic kept my old one, so I need to get a new one.
THANKS!
Old Jul 26, 2010 | 07:09 PM
cheezit's Avatar
cheezit
THANKS!
there are 2 differnet valves they look the same but have different insides. best bet is to find the correct part number.
I got mine around the first of the year and paid $175 or $185
Old Jul 8, 2021 | 09:17 AM
Yzr1's Avatar
Yzr1
cheezit,
Could you give me your advice to:
https://www.ford-trucks.com/forums/1...l#post19960762
tku, I do value your time and appreciate any wisdom you may impart.
Yzr1
Old Jul 10, 2021 | 02:37 AM
Yahiko's Avatar
Yahiko
Originally Posted by Yzr1
cheezit,
Yzr1
This thread is very old and the chance of cheezit responding is not that high. But he may you never know.
I have one engine that was deleted with the "J" tube and it was and easy way to store the valve in the hole.
Nbabballer
Jan 13, 2018 06:05 PM
silverbullet6oh
Apr 17, 2015 07:09 AM
WH 6.0
Oct 28, 2010 07:43 PM
canucklehead2004
Jul 26, 2010 07:31 AM
SShank42
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Oct 6, 2005 05:27 PM
