Missing EGR valve
Old Jan 13, 2018 | 12:38 PM
Nbabballer's Avatar
Nbabballer
Missing EGR valve
Hi guys,
I am new here, I just purchased a 1996 F250 460 with 70k on it. The truck was registered in Flagstaff Az, which doesn't require emissions. I live in Phoenix and from everything I've been reading I will need an EGR valve to pass emissions. I've looked everywhere as to how to add an EGR valve but I cannot find anything on it. The previous owner did provide me with the EGR valve, pipe that connects to the EGR valve and an electronical connection(don't know if it goes to the EGR) . But I don't know whatelse I'm missing.
Old Jan 13, 2018 | 01:36 PM
Tranz zam's Avatar
Tranz zam
Do they do a visual inspection to see if it's actually installed? If not, you should be fine.
Old Jan 13, 2018 | 01:47 PM
'89F2urd's Avatar
'89F2urd
I passed the sniffer with no egr and a modern 3 way cat. I thought I'd fail, but I tried it anyway for poop & gigs because I didn't feel like welding a pipe to the long tubes if I didn't have to.
Old Jan 13, 2018 | 01:52 PM
Conanski's Avatar
Conanski
It is possible your truck never had an EGR valve, is it OBD1 or 2?
Old Jan 13, 2018 | 01:56 PM
Nbabballer's Avatar
Nbabballer
It did have an EGR valve prior. Because of the missing EGR vavle I'm getting codes p0141 and p0147.
Old Jan 13, 2018 | 04:23 PM
rla2005's Avatar
rla2005
You need the DPFE sensor and the hoses that run to the EGR tube. They are made of high temperature silicone. This provides the EGR flow feedback to the computer.
Old Jan 13, 2018 | 05:44 PM
Conanski's Avatar
Conanski
Only if it is an OBD2 truck.
Old Jan 13, 2018 | 06:05 PM
rla2005's Avatar
rla2005
Based on the "P" codes....it's a OBD2 truck.
scottman70
Jul 10, 2021 02:37 AM
WH 6.0
Oct 28, 2010 07:43 PM
cdelsol83
Jul 5, 2010 08:36 AM
jeepin
Aug 26, 2003 11:26 PM
cypherja
1997 - 2003 F150
Sep 26, 2002 07:19 AM
