E4OD overdrive light on
Old Jul 25, 2010 | 07:20 PM
Tom Callan's Avatar
Tom Callan
I have a 1993 Ford F 350 4x4 dually crew cab with an E 4OD transmission. Out of the blue the OD light came on and I don't know what the issue can be. I also noticed that it shifts hard and I've lost the overdrive feature. Any help would be appreciated. Thanks, Tom.
Old Jul 25, 2010 | 07:23 PM
White 97 xlt's Avatar
White 97 xlt
I am not being a smart a$$, but did you by any chance push the button on the end of the shifter? That turns over drive off, and turns the light on..
You have already checked this i'm sure but I just had to ask..
On shifting hard, is the speedometer working?
Old Jul 25, 2010 | 07:28 PM
Tom Callan's Avatar
Tom Callan
E 4OD problem
That was the first thing I checked, thanks for asking though. Years ago I had the same problem and found that the tach sender was at fault but in this case the tach seems to work fine where as before it did not.
Old Jul 25, 2010 | 07:39 PM
White 97 xlt
Another stupid question, do the brake lights and tail lights work? One of them (can't recall which) is on the same circuit with the trans..
I had a problem with the OD switch wires a few years back, and everytime it messed up and blew the fuse I lost tail or brake lights..
Old Jul 25, 2010 | 07:41 PM
White 97 xlt
Also if speedometer is not working the trans will slam into gears as it shifts in "limp mode"
Old Jul 25, 2010 | 07:57 PM
CJM8515's Avatar
CJM8515
The trans is throwing a code, you need to have it checked out.
Old Jul 27, 2010 | 06:00 AM
Tom Callan's Avatar
Tom Callan
Transmission OD light comes on
How can you check for codes?? When I'm going about 40 H.P.H., the transmission will go into and out of OD when I push the button but the light continues to flash. Still shifts too early, any ideas?? Thanks, Tom.
Old Jul 27, 2010 | 07:11 AM
Lazy K's Avatar
Lazy K
Ford Fuel Injection How To Run a Self-Test Here is how to check for trouble codes. A simpler way is to get an OBD1 code reader (can be got for under $30.00).
Tom Callan
Nov 25, 2015 09:59 PM
garagegods
Jul 5, 2015 08:16 PM
prisoner of gravity
Jun 29, 2008 08:38 AM
tom_delonge2289
Feb 10, 2008 11:13 AM
nothingbutford
Feb 7, 2002 08:02 AM
