Bronco II Ford Bronco II
terms
Old Feb 12, 2003 | 09:18 AM
teamkaley's Avatar
teamkaley
terms
good day all! i would like to know what all these terms mean
ITF
MAP
MAF
EEC
ECA?
maybe this knowledge will help me solve my fuel system problem.
thanks!!
Old Feb 12, 2003 | 09:45 AM
mrshorty's Avatar
mrshorty
terms
MAP -- manifold air pressure sensor
MAF -- m*** air flow sensor
EEC -- electronic engine control (ie "computer")
ECA -- same as EEC, just different acronym. even looked it up the other day and can't remember.
Old Feb 12, 2003 | 11:05 AM
teamkaley's Avatar
teamkaley
terms
Is the eec located behind the drivers seat in the little plastic compartment?
Old Feb 12, 2003 | 02:17 PM
mrshorty's Avatar
mrshorty
terms
On my '87, the EEC is located behind the kick panel on the passenger side, just in front of the door and under the glove box. The one behind the driver's seat, I think, is the RABS computer.
Old Feb 12, 2003 | 03:06 PM
teamkaley's Avatar
teamkaley
terms
MrShorty...you are really helping me here and i thank you!!!!!
yes..the one behind the kickplate was the eec-iv and it still cost 95.00$ LOL! but i will run the tests first before buying a new one,but tbefore all of that..i need to find the short in the steering column because the blinker is still shorting out..ah well..my new hobby i guess..lol!!
Old Feb 12, 2003 | 08:07 PM
Ken00's Avatar
Ken00
terms
There is a thread called glossary the has a lot of information on these abreviations as well as a link, this will become a sticky post on the board soon.
Since you are having problems at the column you should check to see if you have power to the EEC relay with the key on, it will only have power for a few seconds and then shut off. My 1989 wiring diagram says that its a R/LG wiring from the switch and a BL/LG going to ground. This wire activates the EEC relay, which activates the fuel pump relay.
2006LJ
Nov 12, 2014 01:07 PM
DHamSTER
137
Nov 16, 2013 05:06 PM
CTom
Sep 11, 2010 08:03 PM
All Things Oval
Jul 30, 2007 08:16 PM
tamwill
Sep 24, 2000 06:39 PM
