Need help and it's bad...
Mine not only dumps a load while driving, it also does it while sitting...
As I said, I watched a movie (Salt, very good movie btw) came back out and found a disturbingly large puddle of oil. So it doesn't take long...
I checked the lines and they're as seated as it's gonna get...they aren't leaking. Once I got everything together, I spayed it all down with Brake Cleaner to remove the oil residue that was on everything. After a lengthy test drive, I looked very closely at the HPO lines at the pump and not a drip...
The leak seems to be coming from the front of the HPOP between the gasket and engine; from there it balloons into something else, concealing the evidence and starting point with oil...
I certainly hope David can tell me what's going on...
See if you can take a peek at Snow White while you are there
After a long week away on business and an even longer day at work, I got up this morning a decided to try and isolate the leak again. Per Bob Riley's instructions, I went to wal-mart, got some white rags, stuffed and wrapped the areas known to leak, and went for a drive. When I came back, I found the rags were sprinkled with oil, but none of them (not the HPOP, Y-pipe, or HPO lines) were convincingly soaked...
While the truck idled I looked over the engine with my spotlight and found this:******** width="480" height="385"><param name="movie" value="http://www.youtube.com/v/Om8nq8R08Kg&hl=en_US&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Om8nq8R08Kg&hl=en_US&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed>*********>
While it isn't conclusive that the HPO resevoir is the culprit and acted alone, it explains everything so far...
When the truck was under load and at speed, it created enough pressure for it to literally soak the engine in oil and conceal itself.
As another user suggested, the rushing air from the front of the vehicle was strong enough to spread the oil accross the engine with the added pressure that was produced while the truck was under load. Since I didn't drive too far or too fast, it couldn't conceal itself again.
To that end, I called the parts department at the local dealership and they tell me it's a whopping $190+tax for the entire resevoir. Lesson learned...
The good news is that it should be relatively simple and not an all day affair...
I'll post back with the results...
I went to my local dealer (Planet Ford) who spent most of the morning finding and getting the resevoir I so desperately needed and left very distraught...
The parts guy at the store did everything he could and really went out of his way for me, but it turns out that the resevoir comes in TWO pieces and not just one like he thought. The bottom piece cost $190 and the top piece (get this) cost $267! Total: $494
The parts guy called around and found one other dealership that had the top part: Tommie Vaughn Ford. If any of you ever need a part, never, ever, EVER go to Tommie Vaughn Ford. It was 2:30 and they closed at 3:00; I called and practically begged the guy there for the part, but he said: "We're not part of the dealership and there's nothing we can do to get you that part. The doors close at 3:00" and hung up...
To that end, I left empty handed and called Dave at DI Performance hoping they would still be open. Dave answered and said he had a few laying around and would gladly sell me one for $200!
I raced over to DI picked up the part and actually got to talk and catch up with Dave. I profusely thanked him, went home, installed the part, went for a drive, and NO LEAKS!
After a good long drive, my truck is back to it's normal self and I feel so much better! Thank you all for your support in all this!
*EDIT* theres still a strangely rough idle, but its something I can live with...for now.
I saw you post in a thread I started that you were experiencing prolonged starts like me... we both have MORE than adequate fuel pressure and plenty of juice at the starter. We both were thinking oil and you just got your new HPOP... does it help at all?
The truck starts easier and takes considerably less pedal to get and keep moving. After taking it easy for a day or so, I mashed it coming out of church and was pressed well into my seat for the first time in years.
The only thing that gets me is that since replacing the pump (and resevoir since I broke it
) with an Adrenaline, it sometimes has a rough/inconsistent idle if you're stopped at a light or parked; even when fully warmed up. May still be some air in the system and lines I guess...
Other than that, my truck runs considerably better than it did new. The injectors are quieter overall and LOVE the new pump. Since yours is an early '99, you have single shot injectors that will love a good aftermarket 17* pump. Whether you go with a Termy modded pump or the Adrenaline, you and your truck will be happy...
About the injectors: I'm almost positive that the single shots ended with the OBS trucks (except for the '97 to '98 CA trucks I think... they had split shots as well). The Super-Duties were when the split shots began. However, my e99 does have a 15* pump so even stepping up to a stock 17* would help some.
But does anyone know what pressure a 15*, stock 17*, and modded 17* put out? Also, did you test yours, OP? I would like to test the pressure on mine because I'd be willing to bet that it's getting tired. I haven't seen the 16-17mpg's I got last year... I've been getting 13-14mpg's. I've been a little heavier on the pedal and have been doing a bit more town/city driving than I did last year, but I didn't think it'd be significant enough to cause it to drop like that. I need to test my back pressure sensor and see if it's plugged up (I replaced the tube because it was cracked/split). Do I have to go to the dealer to find that stuff out?
A Termy modded 17* pump will serve you well, Stewart_H and a few other have one and love it to death. I hadn't seen the 18-19 mpgs I used to get and was getting 14-15 mpg even with my DP-Tuner! Hopefully this pump will fix that unless I just have weak injectors...
I had a local shop test the HPOP with an NGS and it was holding a wimpy 1700psi at WOT with 80 econo. It seems to hold the pressure better now, but I have a feeling I need to replace my EBP tube since it may be clogged.
