Scangauge EBP reading
Old Dec 23, 2011 | 02:52 PM
dr103's Avatar
dr103
What should the back pressure be? I'm running a turbo back MBRP duals with no cat. I input the 6.0 info for the gauge.
Thanks David
Old Dec 23, 2011 | 04:00 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Range is 0-5v. Here is a chart:
<a href="http://bit.ly/shuN1D" target="_blank" />Check out this image!</a>
Also a good thread on cleaning it:
https://www.ford-trucks.com/forums/1...pgs-video.html
Old Dec 23, 2011 | 04:11 PM
fixxxer-upper's Avatar
fixxxer-upper
FTE Fan
2003 up to early 2004 with updated FICM flash no longer uses the EBP sensor. It is calculated using other values. The EBP X-Gauge does not work on these trucks.
Old Dec 23, 2011 | 09:09 PM
freedomfarmer's Avatar
freedomfarmer
I'm getting a reading of 21-23 at 60mph what does that mean ? 03 f250 stock
Looking at banks monster exhaust any suggestions?!
Old Dec 23, 2011 | 10:43 PM
SoCalSuperDuty03's Avatar
SoCalSuperDuty03
I would venture to say your truck has an early strategy in the PCM.
Depending on what state you reside in, many trucks have not had one of the reflashes that eliminated the EBP from the loop.
Seems to me your truck is reading EBP in PSI, as operating range of the sensor itself is 8-88 PSI.
Old Dec 23, 2011 | 10:57 PM
SoCalSuperDuty03
FWIW, if you live in a state that does not require emissions testing, don't let a Ford dealer mess with your truck. Some of the EBP inclusive flashes worked very well. If you have a tuner, you can most likely read the strategy and determine which one you have.
Do your homework on the exhaust system, there are a lot of good ones out there.
djanzen
Sep 16, 2013 07:47 AM
wgouldin
Nov 28, 2006 08:51 PM
KLINE925
Jan 15, 2006 07:10 PM
snowcattinfool
Jun 10, 2005 07:21 PM
