Steering column replacement
Old Jul 24, 2010 | 04:50 AM
strider380's Avatar
strider380
Hi there. I'm new to the forum but have been poking around for years for various fixes. I took my Ford off the road because it seemed like some type of upper bearing went in the non tilt steering <NOBR id=itxt_nobr_1_0 style="FONT-WEIGHT: bold; COLOR: darkblue; FONT-FAMILY: inherit">column</NOBR>. Now I want to fix it and put it back on the road.
Its a 94 E150 with a I6 300 motor. Not sure what tranny.
I dug deep in there and opted it would probably be easier to just swap out the whole top half of the column rather then figuring out how to get that shaft out and back in without problems. I do have a 12ton shop press however if I change my mind. Regardless eveything went smooth, even disconnecting the coupler with the little u joint in it. The one and only thing still holding this together it the tranny shift cable. I can't figure out for the life of my how to get it off. I havn't gone in there really pulling on stuff yet. There seems to be a bracket where the sheathing of the cable ends. This bracket is pretty far woven into the column. I can feel that there is a spot on top for the cable to pop up and out, but I havn't been able to get it. Again I havn't applied any drastic amount of pressure yet, but it feels like I should be turning something or moving something first. I can't see up there, just going by what I feel. In addition to that, the swivel where the cable terminates has my perplexed. there seems to be no screws holding it on and its alot different from the linkages I am used to with carbs, etc that just pop on. Can anyone out there help me? It seems like the whole process is extremly simple if you've done it before. I would really appreciate any assistance. I am so close and need to get out there quick to finish before I forget where all the bolts go.
Old Jul 27, 2010 | 07:23 AM
panici33's Avatar
panici33
Apologize for hijacking your thread, but I figure you have dug into already so I thought I would ask. I have a 93 I6 and I couldn't get it out of park last night after what felt like something broke up on the steering column with the shifter, and now the shifter is completely useless; it just drops straight down with no resistance. Before it got too dark last night, I was able to see that the cable is still intact.
Easy fix or am I screwed?
strider380
Jul 21, 2010 01:49 PM
jdavis_apd
Feb 27, 2010 01:32 PM
Craig5_12
Dec 1, 2004 08:10 PM
vogey
Engine Swaps
Oct 18, 2004 02:33 PM
MustangGT221
22
Nov 12, 2002 02:44 PM
