Shift lever loose
Old Nov 9, 2009 | 11:47 AM
V10E350's Avatar
V10E350
Shift lever loose
On my 07 E350 the shift lever seems loose. In any position, the shifter has play. Not at the shifting mechanism itself, but where the handle bolts to the mechanism.
Any experience with this issue out there?
Old Nov 9, 2009 | 08:56 PM
Grems4ever's Avatar
Grems4ever
Not sure what to tell you on this one. If it is the shifter mechanism on the column, then its likely to need some investigating to determine the cause. My concern is that something could come loose and jam the steering mechanism. Not sure if this is possible due to the design of the column, but it deserves looking into.
Old Nov 22, 2009 | 02:01 PM
hatch_1989's Avatar
hatch_1989
I have a 92 Club Wagon. It has a cast aluminum shift "rod" that runs parallel to the steering column. A lever is bolted to the "rod" at the floor end. Check to make sure the bolts that attach the lever to the "rod" have not backed out. We have had it happen twice. Getting in a position to observe and tighten the bolts can be a challenge. It helps if you are a contortionist.
One other time the cast rod fractured into two pieces and we had no shifter action at all.
Old Jul 27, 2010 | 07:31 AM
panici33's Avatar
panici33
I think this has happened to me...how difficult is it to replace?
greenf150flareside
Jan 27, 2018 05:38 PM
samf1
2004 - 2008 F150
13
Jul 29, 2017 11:50 AM
oldboots1950
Apr 21, 2016 03:20 AM
Fraalan
Apr 14, 2015 07:26 PM
DiscardedFrog66
Sep 16, 2011 07:02 AM
