Elevated Lead in Oil Analysis
Old Jul 22, 2010 | 09:30 PM
Forest's Avatar
Forest
Blackstone is telling me that the last 2 oil changes have been higher than normal on Lead parts per million. This typically indicates a bearing issue. I'm at 80,000 miles and truck runs like a dream.
Can any of you tell me where lead is found in the 6.0 if other than the main bearings? How about the turbo bearing? Camshaft bearings? Any where else?
Old Jul 22, 2010 | 09:32 PM
bismic's Avatar
bismic
Are you using Schaeffer oil?
Old Jul 22, 2010 | 09:37 PM
Forest's Avatar
Forest
I'm using Mobil Delvac1 5w-40 synthetic. Same oil I used in 2003 up to 180,000 miles.
Old Jul 22, 2010 | 09:38 PM
ljutic ss's Avatar
ljutic ss
Main bearings, rod bearings, camshaft bearings.
Old Jul 22, 2010 | 09:40 PM
bismic's Avatar
bismic
How high is it?
Are you using biodiesel?
Are you using a fuel additive?
Old Jul 22, 2010 | 10:05 PM
Forest's Avatar
Forest
12 ppm
Not using any more biodiesel than sold at Walmart
No additives.
Old Jul 22, 2010 | 10:51 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
What's your oil change interval?
Also, curious what the SUS viscosity was.
Old Jul 22, 2010 | 11:33 PM
Forest's Avatar
Forest
5000 mile oil change intervals. The last one went 236 miles over.
SUS viscosity was 63.8 at 210F. (11.28 at 100C).
My viscosities usually run 11.2 to 11.6 cSt.
Last oil change after maybe 3500 miles towing travel trailer in mountains.
Old Jul 23, 2010 | 09:38 AM
69cj's Avatar
69cj
Just for S&G's try a different oil on the next change and see if the readings change. I'm not condemning your oil but on other posts some trucks react differently to different oils. Just something to try that won't cost you any extra money.
Old Jul 23, 2010 | 09:47 AM
Forest's Avatar
Forest
Originally Posted by 69cj
Just for S&G's try a differant oil on the next change and see if the readings change. I'm not condemning your oil but on other posts some trucks react differently to different oils. Just something to try that won't cost you any extra money.
Is there a synthetic oil that is as easy to purchase? Rotella makes one, right?
Old Jul 23, 2010 | 09:51 AM
69cj's Avatar
69cj
Yes, Rotella T-6 is a 5W40 synthetic that is priced reasonably at Walmart.
Old Jul 23, 2010 | 07:52 PM
cheezit's Avatar
cheezit
exact same advise.
Old Jul 23, 2010 | 08:02 PM
bismic's Avatar
bismic
I switched to Schaeffer 9000 and soon thereafter my lead numbers started going up. They weren't too alarming, but above the stated average.
I switched to Valvoline PBE and the lead went back down to the old levels.
Unfortunately the iron started going up. Again - not bad, but I did not like the trend.
I just switched to Rotella T6 tonight - great price at Wal-Mart ($19 for a gallon)
sawyersvintage
Feb 26, 2013 04:51 PM
sunogbahay
29
Sep 9, 2011 12:45 PM
perardua
New Member Introductions
Feb 1, 2006 07:15 PM
GB04
Sep 9, 2005 10:41 AM
fishin1976
Oil & Lubrication
Jul 20, 2003 01:15 AM
