Fuel starvation?
Old Jul 23, 2010 | 05:47 PM
nakoakai's Avatar
nakoakai
Fuel starvation?
Driving on freeway about 65 and engine started running rough. Felt like it was missing or not running on all cylinders, pulled off the road and the engine died. Let it sit for a minute then tried to start. It started but still ran rough. Shut it down and waited again. Next start turned key on and waited till glow plug light and fuel light went out. Cycled key about three times this time started, revved up nicely so off i went. About an eighth of a mile later it did it again. Had it towed home changed both HCFM filter and secondary filter on top of the engine no water in fuel and little rubbish nothing abnormal. Still doing the same thing. Checked for DTC's but no codes using OBDII for codes. Anyone got any ideas or what the problem could be? Its a 2003 F250 PSD about 114,000 miles on it.
Old Jul 23, 2010 | 05:50 PM
Young Gun's Avatar
Young Gun
Did you pull the EGR valve and inspect it?
Old Jul 23, 2010 | 05:53 PM
nakoakai's Avatar
nakoakai
Not yet that was my next project.
Old Jul 23, 2010 | 07:01 PM
cheezit's Avatar
cheezit
check the fuel pressure. if it gets bad enugh many times it will white smoke a little bit.
Old Jul 23, 2010 | 10:35 PM
nakoakai's Avatar
nakoakai
got the two bolts out but the EGR valve will not come out. Any ideas how to get it out.
Old Jul 23, 2010 | 10:37 PM
FSeybert's Avatar
FSeybert
I used a nail puller on one side, and a large flat blade screw driver on the other. Wiggle back and forth, slowly made it's way out. Had mine out this morning, checking for moisture.
Pheadrus
26
Feb 2, 2016 10:39 AM
Skyhawk Greg
73
Sep 15, 2014 10:29 AM
varminthunter243
22
Sep 7, 2014 12:09 PM
dknouse
19
Sep 16, 2010 04:35 PM
tomanycars
Jul 15, 2010 10:27 PM
