Rear Diff
Old Jul 22, 2010 | 06:20 PM
bama29fan's Avatar
bama29fan
Rear Diff
What would be the normal operating temp of the rear diff after pulling 10K for about 30 miles. I dont have gauges so i just shot an infrared temp gauge at the diff cover.
Old Jul 22, 2010 | 07:07 PM
bama29fan's Avatar
bama29fan
i saw in another thread where CSPID suggested 195* as the upper temp for the rear diff.
would shooting the temp off the rear cover be close to what the oil temp is?
Old Jul 22, 2010 | 10:16 PM
Franko72's Avatar
Franko72
Molon Labe
I know its just a reference point, but my Kenworth would stay around 130-150.
I would think shooting the cover would be close, maybe a few degrees cooler...I've never done it, so Im guessing.
Old Jul 23, 2010 | 09:48 AM
bama29fan's Avatar
bama29fan
thanks for your input Frank
Any one else have any?
Old Jul 23, 2010 | 10:14 AM
SteveH-CO's Avatar
SteveH-CO
Towing 2000# for many miles on my F350 resulted in an infra-red diff cover reading of 135F. This is running synthetic 85w-140 - all stock stuff. I realize my trailer doesn't represent much of a load, but it's a data point for you.
Old Jul 23, 2010 | 11:28 AM
Excursion Gary's Avatar
Excursion Gary
Excursion's 4ever!
What's behind the question....curiosity, having a problem??? I recently put on a MagTech Tranny pan and also had my differential clutches replaced. The nut to the pinion gear had backed off so far that I was having some slop in the driveline and vibration on turns. Mypoint was when I asked if heat was a factor and if I needed the MagTech diff cover to help with heat I was told no, heat was not a problem for the 01 X even though I tow a 12k Toy Hauler. Interested in your question......
Old Jul 23, 2010 | 11:35 AM
bama29fan's Avatar
bama29fan
just trying to make sure it ok before heading out for RRE. have about 400 (not a great distance) miles one way to get there and dont want to have any problems. I measured the temp after pulling 10K camper about 30 miles at highway speeds and got 180*F on the cover.
trying to get a baseline to compare it to. i bought the truck about 1 year ago and not sure what all was done to it. the diff fluid is the only fluid i have left to change. i have 154K miles on the truck right now.
Old Jul 23, 2010 | 12:54 PM
Excursion Gary
Excursion's 4ever!
ok, you probably already know this... when towing heavy of greater concern would be the EGT's, do you have a pyrometer? Ig your going to continue to tow heavy then I highly recommend one, along with a tranny temp gauge. If you have a tuner package then you deginately need the pyrometer. What's your setup...and is it all stock?
Old Jul 23, 2010 | 12:56 PM
Excursion Gary
Excursion's 4ever!
aaahhhh.....a whole new world opens up when you learn how to read! I missed the info in your sig. Looks like your set. Have fun!
A/Ox4
Jan 8, 2012 05:44 PM
86f250XLT-4x4
51
Oct 27, 2011 10:57 AM
Danilo
Feb 2, 2011 02:27 PM
MarkMoore
Modular V10 (6.8l)
Aug 22, 2007 07:55 AM
cpd806
Dec 27, 2005 04:17 PM
