Modular V10 (6.8l)
sometimes it starts, sometimes it doesn't
Old Jul 28, 2010 | 03:03 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Did you even TRY pushing on the gas pedal while cranking to see if it starts?
Old Jul 28, 2010 | 03:18 PM
mfg02's Avatar
mfg02
Yes i tried. It doesnt affect it or help it. Initially, before I swapped out the IAC I couldn't get it to not start to try and press on the gas, imagine that. But the part was cheap and easy to swap out so I was hoping to prevent the problem in the future, so much for that. I am getting tired of getting stuck places. Today when it wouldn't start I pressed the gas and it didn't seem to affect anything, so I doubt it is a faulty new IAC. It still cranked for a couple of seconds and then nothing. I tried it about every five minutes for a half hour and could never get it started so I had to get it towed. I'm not sure where to go from here. Any more suggestions????
Old Jul 28, 2010 | 04:43 PM
krewat's Avatar
krewat
When it's doing this "no start" you have to check a few things. Fuel pressure for one. You might have a bad fuel pump. If you don't have a gauge, just get under the truck and whack the gas tank with a 2x4 and see if it'll start. If so, it's the pump.
If there's fuel pressure when cranking, check for spark by pulling a COP and putting a plug in it, and ground the shell of the plug.
dnkensinger
Aug 14, 2016 11:49 PM
RedDevil460
Aug 12, 2016 06:07 AM
mudmagnet63
Jun 2, 2016 06:06 PM
handyandy123
Jul 16, 2015 09:06 AM
jesuscowboy
Aug 11, 2014 07:01 PM
