Goodyear tire issue
Old Jul 22, 2010 | 09:50 PM
sammy77's Avatar
sammy77
Originally Posted by cartmanea
305 is about as wide as I would go, and those were probably E rated so that helps, along with proper tire pressure. It also depends on what stock wheels you have, some are 8" wide and would be okay, some are 7" wide.
Yes they are E rated, I wouldn't put myself or family in danger as I haul real heavy sometimes. I keep the tire pressure at 60psi in front and 65psi in rear. I have 18in stock wheels that I think they're 8in wheel. Not sure though. This is my 3rd set of BFG's on a different truck. Overall great tire would take alot to get me try another.
Old Jul 23, 2010 | 10:53 AM
utahtom's Avatar
utahtom
Originally Posted by deercreek1
I have new Goodyear Duratracs on my F350 and have noticed that my truck feels like I'm driving on "underinflated" tires. Truck is almost scary at 70 mph on the freeway and worse on curves. A lot of swaying and movement from side to side.
Your tire has 18/32 of tread which is more than just about any other tire on the market- What you are probably experiencing is known as tread "squirm" which will decrease over time as the tread wears. The question: Do the off-road and winter capabilities of the tire outweigh the negative handling characteristics? If they don't, then I'd recommend taking the dealer up on the replacement offer.
FWIW I gave up trying to find the perfect all-season tire and have 2 separate sets (Summer & Winter) for each of my vehicles.
Old Jul 23, 2010 | 11:10 AM
excursionism's Avatar
excursionism
I have new Goodyear Duratracs on my F350 and have noticed that my truck feels like I'm driving on "underinflated" tires. Truck is almost scary at 70 mph on the freeway and worse on curves. A lot of swaying and movement from side to side. I see a number of reviews that other people are having the same issue with diesal Fords. Any of you noticing this problem? I have had an alignment done, new tie rod and ball joints. Last tires were BF Goodrich and handled much better.
Was going to pull the trigger this week and order a set of DuraTracs based looks and a review in Off-Road ( ? ) magazine mounted on a F250. After reading all the reviews on TireRack and Discount Tire, started looking elsewhere. Right now it's looking like Coopers or Hankooks.
Old Jul 23, 2010 | 04:37 PM
deercreek1's Avatar
deercreek1
Tire pressure was correct on the Duratracs. My tire rep said they would switch me over to the Nitto's which was what I had previously. Some of the reviews on the Duratrac are not too good. Rumor is that Goodyear may do a recall if there are enough problems reported.
Old Jul 23, 2010 | 04:41 PM
bismic's Avatar
bismic
E rated tires (including the Duratracs) need to be aired up to 70+. The tire recommendation is 80 psig max.
Old Jul 23, 2010 | 04:42 PM
cartmanea's Avatar
cartmanea
Some E-rated tires are rated for less. The Duratrac in 315/75/16 is E-rated and is a 65 psi tire.
Old Jul 23, 2010 | 05:20 PM
bismic's Avatar
bismic
Thanks - I guess will say that MOST "E" rated tires are rated for 80 psig.
bigtexan99
All Things Towing
Apr 15, 2007 06:52 PM
Pathfinder1369
1983 - 2012 Ranger & B-Series
Nov 30, 2004 07:13 PM
mountainman
1997 - 2003 F150
Jul 18, 2004 11:38 PM
84-250
17
Sep 5, 2003 08:37 PM
lyle_o
Aug 3, 2001 02:08 AM
