Offroad & 4x4
4r100 T-case help
Old Jul 22, 2010 | 07:18 AM
doug70's Avatar
doug70
4r100 T-case help
Here is the scenario. I have a 79 F250 4x4 frame. I set a 351W in it, attached the 4r100 from a 97 f350. The problem is the T-case is too big to fit. I would have to cut clear through the bottom of the frame. I hate to compromise the frame to this extent. Is there another T-case that would work? I also have a couple of nv4500's, but advance doesn't have an adapter.
Thanks,
Doug
Old Jul 28, 2010 | 09:32 AM
alpha/omega's Avatar
alpha/omega
how much cutting are we talking about?
Can you clock the t-case some so it clears?
I had this same issue with a 60 CJ5 and a 435/205 deal so I ended up dropping the project until I can figure something else out.
Old Jul 28, 2010 | 11:36 AM
doug70's Avatar
doug70
I probably could have clocked it one bolt hole, but decided to drop the 4r100 in favor of a NV4500 since I had some of those. I ordered an adapter kit from Advanced Adapters. It should be here today. With this trans I can use the BW4401 which is narrow enough to fit. I can also run naturally aspirated(no computer) this way. Anyone need a 4R100 and T-case?
Doug
Old Jul 28, 2010 | 01:28 PM
fatdan460's Avatar
fatdan460
not naturally aspirated, you mean carb instead of injection. carb and injection are both naturally aspirated. a turbo or super charger would be forced induction, the opposite of natural aspiration. just thought i would set you straight on that.
Old Jul 28, 2010 | 04:34 PM
captain p4's Avatar
captain p4
hmm 4r100 and that stupid duty case with teh megalow range? Is that a chain driven case?
I originally went with the sterling because I had plans of someday swapping an EFI 460 and e4od into teh Bronco. (VSS) Mud bogging rednecks from the southern states decided to build me a neck snapping carbed fo'sexay instead. 4spd w/overdrive would still be perty cool though and stronger than my slipping c6.
er nevermind it's out of a '97 that's the chain driven BW case. I thought 4r100's started with teh stupid duty?
ColoradoCool
1983 - 2012 Ranger & B-Series
Apr 8, 2014 01:34 PM
SC78f150
18
Mar 17, 2014 05:38 PM
doug70
Offroad & 4x4
17
Jul 17, 2010 04:00 PM
66f1004x4
Offroad & 4x4
Feb 3, 2010 05:30 PM
