E40D problems --- I think
Old Jul 21, 2010 | 09:06 PM
hammlm's Avatar
hammlm
93-F250-IDI-Extended Cab 4WD
Truck has been running great for some time. (knocking wood all the while).
About 4 weeks ago, after running about 200 miles, I noticed hard shifts and the O/D light on the stalk was blinking. I was close to home, parked it and next day no problem.
No problems since.
Sunday I replaced the rear shocks (old ones could be original -- one of them puked oil all over the drive). I took it out, drove it, all was well.
Drove it again today (Wed) for the first time since.
1 - ABS light is on. WTF?
2 - O/D override flashing, hard shifts.
3 - About a 3 mile drive. On the second "pull over, shut off and restart", it would not shift out of first gear when in "D". If I moved it to second, I had 1st and 2nd gear, but not 3. Shifting back to "D", just have 1st gear. Arggggh. Another "pull over, shut off and restart". Same exact symptoms, but now the O/D override light is not flashing.
Help?
I did notice that on the drivers side, on the rear frame rail, there is a wire loom. There is a wire that is hanging out of the loom, it is green, and looked to be in bad shape, but was still connected. I know I need to get into it and replace the bad part of the wire, but have no idea if that's part of the problem or not.
Thanks!
Old Jul 21, 2010 | 09:25 PM
rupejosh's Avatar
rupejosh
that may very well be the problem does your tach and speedo work properly?changing the fluid and filter does wonders as well
Old Jul 21, 2010 | 09:34 PM
Coalroller's Avatar
Coalroller
i had a similar problem a while back and the fuse (cant remember off hand what number it was) had blown but not fully if that makes sense, it split but the gap wasnt big enough to fit a piece of paper through and the test light still read it was good so i didnt catch it right away and finally after pullin every fuse and goin over them with a fine tooth comb i found the small split in it, hope this helps ya
Old Jul 21, 2010 | 09:52 PM
David85's Avatar
David85
Run a code scan. It seems to me your VSS/ABS sensor isn't sending a signal to the PCM. On your year of truck however, it also drives the speedometer so that begs the question of how your speedometer is working?
Old Jul 22, 2010 | 05:33 AM
hammlm's Avatar
hammlm
Speedo seems fine.
Tach is fine. When I got the truck, the tach was wacky and I replaced the sensor, which made it shift like a dream (three years ago). I didn't really know that it was shifting weirdly until I replaced it. But that was nothing like this ---this is weird.
I'll look @ the fuses and replace that wire next.
thanks.
Old Jul 22, 2010 | 10:06 AM
hammlm's Avatar
hammlm
VSS ABS
David 85:
Is that sensor or sender housed in the rear diff?
Old Jul 22, 2010 | 11:40 AM
David85's Avatar
David85
Yes, your ABS, speedometer sensor is the only electrical plug on the rear differential (pointing forward).
Old Jul 22, 2010 | 11:58 AM
Lazy K's Avatar
Lazy K
As David 85 says you should check for trouble codes. You should be able to get an OBD1 code reader for under $30.00 or you could use the self test and count the light blinks.
Old Jul 22, 2010 | 02:02 PM
hammlm's Avatar
hammlm
Right, I know where it is then (the ABS sensor). Hopefully tonight I can look at it.
I have an OBD1 scan tool, just haven't really gotten anything meaningful out of it ever.
But you can bet I'm going to try to pull codes tonight.
Thanks for the help. As always: good, timely info on this site.
Old Jul 22, 2010 | 02:14 PM
hammlm's Avatar
hammlm
I'm wondering if I banged that sensor or the wire when I was under there changing the rear shocks. It was a bit of a "pretzel move" to get my impact gun and extension up in there for the top nuts. I definitely felt at times like I was making out with the pumpkin / rear diff.
So, god willing, tonight I will:
0 Pull codes and record
1 Check all the fuses
2 Check that sensor
3 Repair the green wire that is sticking out of the loom
4 Test it
5 Pull codes again.
If I have something out-of-sequence, let me know!
Thanks,
Old Jul 22, 2010 | 03:02 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
"3 Repair the green wire that is sticking out of the loom"
if you damaged a wire going to the VSS this makes your trans act very bad.
when i had my bed just bolted on,before i had it fixed/welded up, the hoist came down and pinched those wires and i had to drive home slow and easy due to the trans in a semi limp mode.
Old Jul 22, 2010 | 07:53 PM
hammlm's Avatar
hammlm
Success!
OK, I must have been asleep or something -- I know I wasn't drunk last night, but I would have sworn the speedo was fine. Maybe I was too preoccupied with the tach...???
Anyway, it's all good now.
I tried scanning for codes over and over -- no codes. Started to worry.
I checked all the fuses, OK. Well, there was one under the hood for a trailer signal and stop lights that was blown. I replaced it, re-scanned multiple times, no joy.
Pulled it into the garage, got under there, and sure enough, the wire was sheared right off of that speed / abs sensor. HTF did that happen? DIdn't look like it was all of a sudden kind of cut. Looked dirty and the wires were corroded, etc.
I cut the wires back, stripped them, soldered the connector back on,heat shrinked the connections and put the loom back in the holders. Added a couple of zip-ties just to be sure.
Turned it on, no ABS light. Yay! I think I forgot to mention that.
I scanned, still no joy. Then I noticed there was another plug in the EEC housing. I pulled that sumbich out, and plugged it into the scan tool and PRESTO. (yes, I can be a dumba$$)
I got 11 1 11 on the Key On Engine Off, then on the Key On Engine Running, I got the 5 indicating 7.3 diesel, and then 74. When I read what 74 was, I re-ran it, after the 5 pulse engine ID, I hit the breaks and then I got 11.
So KOEO is 11 - 1 - 11 and KOER is 11. Looks like I'm in good shape.
It shifts so smooothly now. I think the wire must have been sending a half-*** signal for a while. It hasn't shifted like this since I don't know when.
Next project is to fix that green wire out of the loom that I didn't touch tonight.
You guys all rock and always solve my little problems!
This place is the best
Old Jul 22, 2010 | 09:04 PM
rupejosh's Avatar
rupejosh
glad to see your all squared away!!!!
Old Jul 22, 2010 | 10:33 PM
FORDF250HDXLT
cool indeed!
you may think of this as a little problem,but it would have caused a trans failure in the not so distant future i bet.
you just can't beat FTE man
some people don't like the E40D due to its "complicated electrical troubleshooting problems". but research has shown,this trans is worth its weight in gold.(huge thanks to david85[trust me when i tell you,as humble as he is,the average person has no clue how much we owe him] & Mark-the engineer.)
all you need is common sense on what to do when problems arise,and FTE to help you fix them,and this trans is as good as $ in the bank.
Old Jul 23, 2010 | 12:18 AM
David85's Avatar
David85
Gotta love those easy ones!
